Saitel DR - How to set up a CPU redundancy
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • Saitel DR - How to set up a CPU redundancy
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
YasserRagab
YasserRagab
Cadet
Posted: ‎2025-07-22 11:20 PM . Last Modified: ‎2025-07-24 01:20 AM
468
I appreciate your support. I want to confirm whether the Saitel DR supports CPU redundancy and can operate in Hot Standby (HSBY) mode. If possible, share a schematic diagram of redundancy.
  • Saitel range
Tags (4)
  • Redundant CPU
  • redundant Saitel DR CPU
  • Saitel DR
JuanRayo
Lt. Commander JuanRayo Lt. Commander
Lt. Commander
Posted: ‎2025-07-24 12:23 AM
Hello Yasser.
The answer is easy: "yes". Saitel DR supports cpu redundancy, I am attaching a link to a document where you can read more about this topic (from page 66)
HUe - User Manual _EN_09.pdf
I am also adding a picture captured with an example of a diagram of redundancy. Hope this helps you sir.
JuanRayo
Lt. Commander
Hello Yasser.
