Re: Micom P14 lockout 8c0f:0000
Protection & Control
Send InviteCancel
The error code 0x8C0F0000 is related to the main sampling buffer. This maintenance occurs if the buffer becomes full.
Yes, you can reboot the relay by switching off and on the power supply and recover it The relay must be repaired if the error persists or if it occurs again and again.
