PowerLogic P5 Zigee TH110 and CL110 pair
Protection & Control
Select a Country
  • EcoStruxure Power & Grid
  • Protection & Control
  • PowerLogic P5 Zigee TH110 and CL110 pair
Araceli_Monje
Araceli_Monje Mentor
60
Arun-kumar_PS
Arun-kumar_PS Mentor
26
JuanRayo
JuanRayo Mentor
24
Back to Protection & Control
sesa197124_brid
sesa197124_brid Contributor
Contributor
Posted: ‎2025-01-10 01:43 AM
1912
Dear All,
Is there a procedure of pairing PowerLogic P5F30 with new hardware B with firmware V02.501 + REL51044 with one sensor CL110.
  • PowerLogic P5
Shaogang_WANG
Shaogang_WANG Mentor
Mentor
Posted: ‎2025-01-10 02:11 AM
Hello @sesa197124_brid,
Please find one part of user manual attached which includes the sensor pairing in chapter 'Pairing of sensors', the process is described in detailed I think. Please let me know if you have more questions.
Replies 8
Shaogang_WANG
Mentor
Igormugnos
Igormugnos Explorer
Explorer
Posted: ‎2025-12-15 05:04 AM
1013
Hi, what should i do when the board shows like this? (it was working and stopped)
wasabi
wasabi Contributor
Contributor
Posted: ‎2026-03-11 11:31 PM
865
Could I confirm if the sensors can be re-allocated from P5 to another P5 simply by copying its RFID inside the configuration file ? similar to the old ZBRN where you could copy its line of code inside the csv file..
lucy
lucy Contributor
Contributor
Posted: ‎2026-03-22 10:33 PM
Hello @wasabi,
No, simply copying RFID can not restore the Zigbee connection from P5 A to P5 B. Please refer to P5 user manual and search "PowerLogic P5 is replaced" for the detailed solution.
lucy
lucy Contributor
Contributor
Posted: ‎2026-03-23 12:51 AM
823
Hello @Igormugnos,
Is the issue solved? If not, can you provide more details?  Which operation did you do prior to this abnormal status?
Igormugnos
Igormugnos Explorer
Explorer
Posted: ‎2026-03-23 05:14 AM
Hi!
It was solved in another topic that i've opened here.
thanks
wasabi
wasabi Contributor
Contributor
Posted: ‎2026-04-12 05:01 PM
730
I just have 1 more question regarding the module REL51044, this is labeled as EXR and its got a RJ45 port, may i know what they are used for ? if the P5 already have comms via another module then what is this RJ45 for ? is it modbus TCP ? thanks
Shaogang_WANG
Mentor
Posted: ‎2026-04-12 07:33 PM
Hello @wasabi,
Please refer to description from manual as below. The RJ45 on EXR is not used for Modbus TCP/DNP3 TCP/IEC61850/etc, but IRIG-B/CLIO/RTD/ZigBee communication.
