P3L30 Calculation
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • P3L30 Calculation
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
Back to Protection & Control
Hendra393652
Hendra393652 Cadet
Cadet
Posted: ‎2024-02-02 02:52 AM
1362
P3L30 Calculation
Dear All,
I need help for the explain example case in the attachment file this below.
Best regards,
Hendra Kusumah
  • PowerLogic P3
Replies 4
Hendra393652
Hendra393652 Cadet
Cadet
Posted: ‎2024-02-05 01:37 AM . Last Modified: ‎2024-02-05 01:41 AM
1316
our relays had been tripped on customer site and we need to give clarification to them.
we found on the fault log & disturbance recorder that the magnitude and phase of the currents are quite similar (attachment slide 2). but we don't know why the relays indicate that the differential protection 1-2-3 operated (attachment slide 1).
kindly please advise.
the setting of both relays are available on attachment slide 3.
thank you.
Pete_Vivers
Captain Pete_Vivers Captain
Captain
Posted: ‎2024-02-05 11:39 PM
Hello, These sorts of issues should be managed by using BFO. If not already done so please raise a BFO issue to ensure that it is tracked and has priority
hugoNP
Crewman hugoNP Crewman
Crewman
Posted: ‎2024-04-10 03:23 AM
Hi team,
Hendra and me have tried to understand the sample case provided in the manual book, but it seems miss some details and have many typos.
We try to come up with the calculation excel (with what we understand), as attached. Hopefully the formulas are correct and it could be helpful to all of you.
Thank you.
P3L30 Diff Calculation v2.zip
Chunmei_Yang
Lieutenant JG Chunmei_Yang Lieutenant JG
Lieutenant JG
Posted: ‎2024-05-09 07:35 PM
Hello:
 Nominal primary setting is intended to accommodate possible transformer on line, however for cable It must be the same on both ends.
I notice the settings for nominal current is different :
Propose to check the power system if a transformer included, then configure the correct nominal primary current.
Chunmei
