External power supply for VAM 12LSE modules
Protection & Control
  • EcoStruxure Power & Grid
  • Protection & Control
  • External power supply for VAM 12LSE modules
Araceli_Monje
Commander Araceli_Monje Commander
43
Arun-kumar_PS
Commander Arun-kumar_PS Commander
21
PowerLogic
VAMP Arc Protection
Back to Protection & Control
Milica_Repac
Lieutenant JG Milica_Repac
Lieutenant JG
Posted: ‎2022-10-07 03:12 AM . Last Modified: ‎2023-05-30 10:04 PM
1852
Hello everyone,
can someone give me information considering power supply for VAM 12LSE modules.
If there is a arc flash protection system with more then four VAM modules is it necessary to use a seperate external power supply +24Vdc or not?
Thank you.
Best Regards
  • Thumbnail of VAMP Arc Protection
    PowerLogic
    VAMP Arc Protection
View products (1)
  • Application cases
Tags (4)
  • arc flash protection
  • Power Supply
  • VAM 12LSE
Reguram_A
Ensign Reguram_A Ensign
Ensign
Posted: ‎2022-10-07 03:33 AM
Hello @Milica_Repac,
I have attached different conditions that you have to check in a Arc flash system in order to choose separate +24Vdc external power supply.
If your system demands for an external power supply then you can use any one of the below external supply unit with voltage output monitoring.
  • ABL4RSM24035 (3.5A @ 24Vdc)
  • ABL4RSM24050 (5A @ 24Vdc) or any equivalent type of power supply with above functionality
Use of power supplies without voltage monitoring is not recommended.
Hope this information is helpful for you.
Best Regards,
Reguram A
Reguram_A
Ensign
Best Regards,
Reguram A
