I am experiencing an issue with my IEC 61850 configuration on the RTU. I imported ICD files from an ABB relay into the Easergy Builder application, but when I send the configuration to the Saitel DR RTU, I receive a Data Mismatch error.
The protection and digital signals are coming through correctly, but the analogue data is causing the mismatch.
Below are the diagnostics I receive when sending the configuration that includes the analogue data tags.
Please assist.
i do not get these errors when I only have the Protection and Digitals.
Hello Lanos,
I think the problem is that the IED does not have the dataset in the same order as your imported CID.
What I would do is use IEDScout or IEDExplore to see what the IED has loaded.
Best regards
hallo,
I did use IEDExplore and the datasets match. The problem is just with the analogues.
kind regards
Hello . I think @SESA219022 is correct but to determine the exact point where the problem occurs I need you to share with us the configuration used and wireshark traces captured after a disconnection with the IED¨s affected.
