caught unhandled exception when i open EcoStruxure Power Design - Ecodial INT V4.98
  • Power Distribution IEC
  • caught unhandled exception when i open EcoStruxure Power Design - Ecodial INT V4.98
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-09-15 01:32 AM . Last Modified: ‎2024-11-22 04:25 AM
10
4176
  • Power Distribution Software
bgt-nl
Crewman bgt-nl
Crewman
Posted: ‎2023-04-24 11:22 PM
In response to bgt-nl
Problem solved. In my case the "c:\00data\admin\My Documents" folder is inaccessible due to company restrictions and therefore needs to be updated to a folder that is accessible.
Open explorer, right click on "My Documents" folder and select "Properties" then select "Location" tab and change to a folder that is accessible according to your account priveledges. Could then open EcoDial.
Replies 10
Genghiz
Captain
Posted: ‎2022-09-22 04:09 AM
Hello
Thanks for reaching us through the Forum.
To understand the situation / scenario in deatil...Can you please kindly provide some additional information?
If possible enclose a Snap (screen capture) Or the ecodial project file (.eac) by which you are facing this scenario.
Thanks you,
Team - Ecodial Expert Support
bgt-nl
Crewman bgt-nl
Crewman
Posted: ‎2023-02-15 04:02 AM
3896
I have the same problem, where the following exception was logged.
2023-01-18 20:25:42,507 [1] FATAL SchneiderElectric.CustomerSoftware.SRP.CompositeApplication.App - System.UnauthorizedAccessException: Toegang tot het pad c:\00data\admin\My Documents\Schneider Electric\EcoStruxure Power Design - Ecodial is geweigerd.
Is there a way to change the path in one of the XML config files? Our system doesn't allow a user to make use of the admin folder and therefore Ecodial will never work on our companies network.
Genghiz
Captain
Posted: ‎2023-02-20 12:32 AM
3877
Hello
Thanks for reaching us...
Thanks for your interest in Ecodial.
In general, you should have a admin rights to install and use the application. Any specfic file at the installed directory can not be modified for this purpose.
Thanks for your understanding.
bocatorix
bocatorix
Cadet
Posted: ‎2023-04-19 01:23 PM
In response to Genghiz
3793
Hello, the same happen to me. When i open the program, it say i need to register and when i press okay  the problem appear. The program close after that.
Karthikeyan1
Lieutenant JG Karthikeyan1 Lieutenant JG
Lieutenant JG
Posted: ‎2023-04-19 09:10 PM
In response to bocatorix
3781
Hello Bocatorix,
Kindly provide additional informations.
1. Which version of EcoStruxure power design - Ecodial are you using?
2. Which version of Windows are you using?
3. Do you have admin access to your system?
and if possible please attach the error screenshots.
As a development team, we advise you to use the latest version available. You can download the latest version below URL.
https://www.se.com/il/en/product-range/61013-ecodial-advance-calculation/
Kindly post it here, whether your problem is solved after using the latest version.
Thanks & Regards,
bocatorix
bocatorix
Cadet
Posted: ‎2023-04-20 02:06 AM
In response to Karthikeyan1
Hello
For your requested information:
I use the latest one, in the program name it say it is V5.00
I use windows 10
I have the admin access in my computer.
Also before this problem i get the problem with the .Net framework but i solved it.
After this, when i click acept, the program close.
Thanks so much.
bgt-nl
Crewman bgt-nl
Crewman
Posted: ‎2023-04-20 02:24 AM
Currently running Ecodial V5.00
Windows 10 Version 22H2 (OS Build 19045.2846)
.NET Framework 3.5 including .NET 2.0 & 3.0
.NET Framework 4.8 Advanced Services
Currently admin user
bgt-nl
Crewman bgt-nl
Crewman
Karthikeyan1
Lieutenant JG
Posted: ‎2023-04-25 04:53 AM
Thank you so much Bill. It will be really helpful for several users who are struggling with this particular issue.
Thank you for your effort.
Alain2024
Alain2024
Cadet
Posted: ‎2024-10-14 09:24 AM
1. open start menu>
2. Write CMD>
3. right click on Comand Prompt and select Open as an Admin>
4. C:WINDWS\system32>sfc /scannow
5. wait until the scan finishes.
6. restart your computer.
