What is IEC Standard for Busway ? Apakah standar IEC untuk Busway / Busduct ?
  • Power Distribution IEC
  • What is IEC Standard for Busway ? Apakah standar IEC untuk Busway / Busduct ?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
HelvinHermanT
Admiral HelvinHermanT Admiral
Admiral
Posted: ‎2021-04-15 09:19 PM . Last Modified: ‎2021-10-27 11:03 AM
The IEC standard for Busway trunking system is IEC 60439-2 and IEC 61439-6 as the latest standard.
IEC 60439-2 consist of 14 type test & routine test.
IEC 61439-6 consist of comprehensive construction & performance verification for safety & reliability. It consists of 25 design verification & routine test. IEC 61439-6 is the latest IEC standard for Busway trunking system.
Standar untuk Busway / Busduct adalah IEC 60439-2 dan IEC 61439-6.
IEC 60439-2 terdiri dari 14 pengujian tipe & pengujian rutin.
IEC 61349-6 terdiri dari pengujian untuk kontruksi & performa untuk keamanan dan kehandalan. Terdiri dari 25 pengujian disain dan pengujian rutin. IEC 61439-6 adalah standar terbaru dari Standar IEC untuk Busway / Busduct.
Untuk menjamin performa produk sebaiknya mengikuti standar terbaru.
IEC 61439-6 25 verifications :
10.2.2 Resistance to corrosion
10.2.3.1 Thermal stability
10.2.3.2 Resistance to abnormal heat and fire due to internal electric effects
10.2.4 Resistance to ultra-violet (UV) radiation
10.2.5 Lifting
10.2.6 Mechanical impact
10.2.7 Marking
10.2.101 Ability to withstand mechanical loads
10.2.102 Thermal cycling test
10.3 Degree of protection of assembly
10.4 Clearances distances
10.4 Creepage distances
10.5.2 Effective continuity between the exposed conductive parts of the BTS & the protective circuit
10.5.3 Short-circuit withstand strength of the protective circuit
10.6 Incorporation of switching devices and components
10.7 Internal electrical circuits and connections
10.8 Terminals for external conductors
10.9.2 Power-frequency withstand voltage
10.9.3 Impulse withstand voltage
10.10 Temperature-rise limits
10.11 Short-circuit withstand strength
10.12 Electromagnetic compatibility (EMC)
10.13 Mechanical operation
10.101 Resistance to flame propagation
10.102 Fire resistance in building penetration
@Nedi
  • Power Standards & Regulations
  • bahasa Indonesia
Replies 0
