TransferPacT - How to Install Function Module
  • Power Distribution IEC
  • TransferPacT - How to Install Function Module
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
TransferPacT
ClémencePICOT
Ensign ClémencePICOT Ensign
Ensign
Posted: ‎2022-06-16 12:13 AM
1
2785
TransferPacT is the new generation transfer switch by Schneider Electric that provides best-in-class reliability with ultra-fast transfer performance. This natively connected switch can be monitored 24/7 and thanks to the modular design, it’s easy to upgrade.
How to video demonstration for install the function modules on TransferPacT Automatic and Active Automatic transfer switches. This is a supplemental reference to the TransferPacT instruction sheet.
Benefits of TransferPacT
  • Power Availability
Innovative technology to ensure ultra-fast transfer performance.
Short circuit capabilities and best-in-class electromagnetic protection, exceeding industry standards on class B.
With an operating temperature ranging from -25 to 70 °C.
Vibration tests are carried out in compliance with IEC 60068-2-6.
Defined and clear coordination table with upstream protection to protect properly your ATS and electrical installation.
  • Efficiency & simplicity
Modular design with end-to-end product life cycle management.
Space-saving with a compact design, easy to install with embedded bridging busbars.
Upgradeable functional modules with plug-and-play non-disruption maintenance.
Dielectric test of the panel without disconnecting power cables with dielectric switch.
Green Premium offer and green packaging to save valuable resources.
  • Natively connected with EcoStruxure Power
TransferPacT enables 24/7 precise power monitoring on voltage, frequency, voltage unbalance, and phase rotation.
Predictive maintenance with monitoring software that can analyze performance and alert data to provide recommendations proactively.
Easy access to all product-related documents from your mobile devices
Learn more about TransferPacT ranges
Clémence PICOT
Channel Marketing Leader
Power Products Division
  • How to
  • Products
J_Travostino
Sisko
Posted: ‎2022-06-21 02:37 AM
And do not forget to check out the other videos of this "TransferPacT How To..." series here 👇
> TransferPacT - How to Manual Operate and Padlock
> TransferPacT - How to Install Auxiliary Contacts
> TransferPacT - How to Connect Automatic Transfer Switch
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
J_Travostino
Sisko
Julien Travostino
Power Products Div.
