Stunt Trip
  • Power Distribution IEC
  • Stunt Trip
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2022-07-15 08:36 AM
896
Stunt Trip
How do you a stunt trip remotely? What do you have to fit or operate in order to do this?
just curious because we are fitting these on busway tap offs on a job in the near future?
kind Regards
Christian_Bach
Lt. Commander Christian_Bach Lt. Commander
Lt. Commander
Posted: ‎2022-07-17 11:45 PM
Hello @Anonymous user ,
Do you mean "shunt trip" ?
If yes, shunt trip is also named "undervoltage coil". It is a specific accessory allowing to open a circuit when it is de-energized, by tripping the breaker.
Basically you have to connect it to a permanent voltage source, and use a switch or contact to open the circuit in case of need. Once the breaker is tripped, you can either reset it locally or through a motor mechanism remotely.
A typical application is emergency stop buttons on machines, because of the "safe" fall back position of the system in case of power or connection issue.
Hope that helps.
Christian
Christian_Bach
Lt. Commander
Hope that helps.
Christian
