Posted: 2024-01-23 03:55 AM
Hi.
I am attempting to connect to a known static IP of an installer Smart Wallbox charger, but all it shows in GUI is Server Error after going through the sertificate error that always shows.
See attached image for screen dump of what developer tools in Mozilla shows, general error 500 so not much to help bypass it there...
Is there any way for me to force a connection to this charger via SSH or similar means, or force a change internally to fix this Server Error fault?
Posted: 2024-01-31 09:32 AM
Posted: 2025-01-17 01:52 AM
Hi Louis.
See attached image below, it opens just fine on my end in my previous comment.
This ended up being related to 3.4.0.7 was the reply given by technical support once we found a solution, replying here with the info in case someone else runs into the same issue.
