Single Phase supply
  • Power Distribution IEC
  • Single Phase supply
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Design – Ecodial
Posted: ‎2022-01-23 04:00 PM . Last Modified: ‎2024-11-22 04:25 AM
2059
Single Phase supply
Hi!
I'm getting started in Ecodial, and I want to know if it's possible to stablish a single phase company supply. The available supply method for low voltage is three-phase only, and there is no option to choose for 1 phase.
Its for a house electric board design.
Thanks!
  • Power Distribution Software
  • Single Phase Supply
Genghiz
Captain
Posted: ‎2022-01-23 10:06 PM
Hello Matias,
Thanks for your query on Ecodial.
The "list of sources" available at the circuits library is only having 3P+N source; and there is 'no single phase' source is available to select (Or define).
To build the single phase network; may be you can try to define it below the "LV LV transformer". For which you should connect and define a "single phase switchboard" below the LV LV transformer' as shown here.
Note : This application is not meant to build a 'residential electrical network.' On the other hand, this can be used for a 'residential complex' or a multistory apartment network.
Thanks & Regards,
Team - Ecodial - Expert Support
Genghiz
Captain
Hello Matias,
Thanks & Regards,
