Schneider Panel Board MG6C12
  • Power Distribution IEC
  • Schneider Panel Board MG6C12
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Techno
Techno
Cadet
Posted: ‎2025-03-26 09:45 AM
402
Hi, can anyone tell me the maximum cable size that will terminate in above MCCB panel Board. The client has a factory, and UK  Power Networks are installing a new 350kva metered supply into client GRP unit some 85m away. We are running 4 x parallel 150mm 4core pvc/swa cables, and need to terminate at both ends. At present we think terminating into Bus bar chamber and spreader box at both ends , with a 800amp main switch on busbars at Uk power network end, and busbar and spreader box at existing panel board end. The problem is final connections between both ends, single cables could be quite large. Any Ideas?
  • Power Availability
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-03-27 05:20 AM
Hello @Techno, thank you for your post, we'll come back to you!
