NS Device identification issue in EPC (Ecostruxure Power Commission)
  • Power Distribution IEC
  • NS Device identification issue in EPC (Ecostruxure Power Commission)
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
ComPact NSX
Baljit
Crewman Baljit Crewman
Crewman
Posted: ‎2023-03-13 03:46 PM
2276
Hi Guys,
I've come across an issue at site where Non-Auto NS MCCB (Non-communicating) and ML5 NS MCCB (Non-communicating) are not getting identified in EPC. EPC did locate the NS devices with default name BCM-ULP however when we try to connect to device, it shows error "Device identification is not successful".
See attached photos and advise what could be the issue here.
Just for info - We did try to test in lab with EPC connected to just BCM-ULP, it worked fine.
  • EcoStruxure Power Commission (EPC)
Gregoire_Brun
Commander
Posted: ‎2024-03-20 06:41 AM
hello @Baljit,
Thanks for this default identification, I share it with EPC team, They will correct this point as soon as possible.
Gregoire Brun
Breaker Product Expert
Replies 4
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2023-03-28 03:02 AM
1
2228
Hi @Baljit
Hope you had received the response from tech support.
Thanks!
Regards
Udhayakumar A K
ESXP System Support Expert
Baljit
Crewman
Posted: ‎2023-03-28 03:42 PM
In response to UdhayakumarAK
Hi @UdhayakumarAK - Did receive response but response conflicts with what we personally checked in lab. In the lab we simulated by connecting IFM module to just BCM-ULP module without any connection to trip unit and EPC was able to identify and read BCM-ULP. Though we know the information displayed wasn't correct as BCM-ULP wasn't connected to trip unit.
This is interesting.
Solex94
Solex94
Cadet
Posted: ‎2024-02-21 05:25 AM
Good morning.
I have the same problem as you. Commission detects the BCM_ULP but fails to connect to the NS.
I hope a solution will be proposed soon...
  • BCM_ULP
Gregoire_Brun
Commander
hello @Baljit,
Gregoire Brun
