Posted: 2022-06-24 02:12 PM . Last Modified: 2022-06-29 02:26 AM
We have been working on this charging station to add it to our OCPP platform, but all our attempts lead nowhere, we have read all the related documents, and note that the module we have has no modem, so we connect it to an external internet connection, below is our OCPP configuration, can anyone share his experience in this matter, please?
# Ocpp Conf
[OCPP]
ocppVersion= 1.6
ocppCentralAddress= wss://ocpp.gab.com/websocket/CentralSystemService/
ocppBoxLocalPort= 8080
ocppBoxPublicIp= UNDEFINED
ocppBoxPublicPort= 8080
ocppBoxLocalSSL= 0
ocppBoxAddressReplyTo= http://www.w3.org/2005/08/addressing/anonymous
ocppModemIpAddress= UNDEFINED
ocppModemPresence= 0
modemType=
confModemRetryInterval= 30
boxIdentity= EVLINKSA
defaultIdTag= UNDEFINED
isMeterValueSimulated= false
MeterValuesAlignedData= Energy.Active.Import.Register
MeterValuesSampledData= Energy.Active.Import.Register
meterValueSampleInterval= 900
clockAlignedDataInterval= 0
ocppConnectTimeOut= 60
WebSocketPingInterval= 10
MinimumStatusDuration= 0
TransactionMessageRetryInterval=60
TransactionMessageAttempts=500
truncateBootNotificationsSerialNumbers= true
clientHttpsOptions= DEFAULT
cacheListEnabled= false
enablePlugNumbering= false
enableDoubleNotification= false
lastAcceptedOcppCentralAddress=
lastAcceptedBoxIdentity=
lastAcceptedHeartBeatInterval= 14400
compressDiagnostic= 1
ocppEMDegradedModeEnabled= 0
EnergyLimitValue= 0
isEnergyLimitedActive= false
Posted: 2022-06-28 05:15 AM
Hi Louis,
I found the issue, I was using secured protocol assuming the unit supports it (wss://), but actually, I should have used (ws://) instead.
Thanks for your concern.
Nabieh
Posted: 2025-03-05 10:20 PM
Hello
If you want some meters values between the start and the stop transaction requests, you have to set the MeterValueSampleInterval and the MeterValuesSampledData with the measurands needed.
Please check the OCPP guide : https://www.se.com/fr/fr/download/document/GEX1969200/
Best regards
Louis
Posted: 2022-06-28 05:05 AM
Hello
Can you contact the Customer care center and create a ticket ? Please attache the maintenance report of the charging station.
Posted: 2025-03-04 05:46 AM
Hi Louis, the EVlink pro AC is connected to our backend and the charger is initiating the charging session with the app authorization, but it is not giving any meter after the charger initiated the charging session. If we check the CPO logs once the charging initiated it give only heartbeat.
| Heartbeat | |
| StatusNotification | {"info": "", "vendor_id": "Schneider Electric", "vendor_error_code": "0.0", "connector_id": 1, "error_code": "NoError", "status": "Available", "timestamp": "2025-02-20T08:00:51Z"} |
| StopTransaction | {"meter_stop": 562171, "timestamp": "2025-02-20T08:00:27Z", "reason": "EVDisconnected", "transaction_id": 9291} |
| StatusNotification | {"info": "EV side disconnected", "vendor_id": "Schneider Electric", "vendor_error_code": "0.0", "connector_id": 1, "error_code": "NoError", "status": "Finishing", "timestamp": "2025-02-20T08:00:37Z"} |
| Heartbeat | |
| Heartbeat | |
| StatusNotification | {"info": "", "vendor_id": "Schneider Electric", "vendor_error_code": "0.0", "connector_id": 1, "error_code": "NoError", "status": "Charging", "timestamp": "2025-02-20T07:49:30Z"} |
| StartTransaction | {"connector_id": 1, "meter_start": 560240, "id_tag": "USER8", "timestamp": "2025-02-20T07:49:22Z"} |
| Authorize | {"id_tag": "USER8"} |
| RemoteStartTransaction | {"id_tag": "USER8", "connector_id": 1, "charging_profile": null} |
| StatusNotification | {"info": "Electric vehicle connected.", "vendor_id": "Schneider Electric", "vendor_error_code": "0.0", "connector_id": 1, "error_code": "NoError", "status": "Preparing", "timestamp": "2025-02-20T07:48:53Z"} |
Hello
Best regards
Louis
