Isolator Icw - 50KA but different durations
  • Power Distribution IEC
  • Isolator Icw - 50KA but different durations
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
MoBawy
Crewman MoBawy
Crewman
Posted: ‎2025-10-21 02:10 PM
342
Hi all,
I'm using this switch disconnector
31340 - switch disconnector, Compact INS2500, 2500A, standard version with black rotary handle, 3 po...
and the Icw assigned with it is snipped below
Can someone shed light on why / how does it have Icw = 50KA at different durations? and which one should I use for calcs
  • Knowledge
Gregoire_Brun
Commander
Posted: ‎2025-10-29 01:46 AM
hello @MoBawy the certified value for this product was 50kA for 1s and performence at 0.5s was added without calculation update, maybe it's possible that Icw was better at this time but wa haven't tested and certifiy the limit of the product at this time so by security we have include same curent at this time.
Gregoire Brun
Breaker Product Expert
Gregoire_Brun
Commander
Posted: ‎2025-10-22 01:11 AM
337
hello @MoBawy
All depends about the triping time seting you select for associate breakers.
As I know generaly for IEC 61439 certification generaly it's time at 1s witch are requested but it depends about customer specification...
Gregoire Brun
MoBawy
Crewman MoBawy
Crewman
Posted: ‎2025-10-23 01:28 AM
In response to Gregoire_Brun
but I understand there is a relations that is generally valid up to 3 sec which is I^2t = constant
so if a device can have 50KA for 0.5S .. it shouldn't be able to tolerate 50KA for 1S
For example 50KA for 1s and 30KA for 3s  is understood to me.. but not 50KA for 0.5s and ALSO 50KA for 1s .. it should be less???
Gregoire_Brun
Commander
Gregoire Brun
