How to connect a scanner to Ecostruxure Power Commission?
  • Power Distribution IEC
  • How to connect a scanner to Ecostruxure Power Commission?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Commission
JimmyFSA
Crewman JimmyFSA
Crewman
Posted: ‎2021-12-03 01:27 AM
1394
Dear Community,
I would like to connect a scanner to pair a lot of PowerTag to many SmartLink device before the commissing in our Custemer's infrastructure.
I bought a scanner Zebra DS3608 and I tried to connect this scanner to EPC. I scanned the Code Bar to pair the scanner but it doesn't work? I've the following message: "Failed to connect to scanner. Please try again"
I didn't find anything about this topics in the user guide or on Exchange
must I change the COM port on my computer? is there another configuration to do?
Could you help me please?
Drivers and pilot are up to date.
EcoStruxure Power Commission Version : 2.22.1 Last update : 11/22/2021 10:39:27
Best regards
Jimmy
  • How to
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2021-12-03 01:45 AM
Hello
First of all, I confirm that the scanner DS3608 bought is compatible with EPC.
I recommend you to test it in another USB port in your computer. or on another computer with EPC installed
If you haven't success, please contact our local technical support to find a solution.
Best regards
EPC_Leader
Lt. Commander
Hello
Best regards
