How to calculate voltage drop in a distribution line?
  • Power Distribution IEC
  • How to calculate voltage drop in a distribution line?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-01-30 02:08 AM
1
1911
Calculating voltage drop in a distribution line is important for ensuring that the electrical system operates efficiently. Here’s a simple formula you can use:
Voltage Drop (Vd) = (2 × K × I × L) / 1000
Where:
  • Vd = Voltage drop in volts (V)
  • K = Resistivity constant (ohms per mil foot) of the conductor material (e.g., copper or aluminum)
  • I = Current in amperes (A)
  • L = One-way length of the conductor in feet (ft)
Steps to Calculate Voltage Drop:
  1. Determine the current (I) that will flow through the conductor.
  2. Find the length (L) of the distribution line.
  3. Identify the resistivity constant (K) for the conductor material you are using.
  4. Plug these values into the formula to calculate the voltage drop.
Example: If you have a copper conductor (K = 12.9 ohms per mil foot), carrying 20 A over a distance of 100 ft, the calculation would look like this:
Vd = (2 × 12.9 × 20 × 100) / 1000 = 25.8 V
This means the voltage drop would be 25.8 volts.
Remember, it's essential to keep the voltage drop within acceptable limits (usually less than 3% for branch circuits) to ensure efficient operation.
Schneider Electric Electrical Calculation Tool
Discover EcoStruxure Power Design – Ecodial
  • How to
  • Knowledge
jake.falcon
Crewman jake.falcon Crewman
Crewman
Posted: ‎2025-02-07 06:37 AM
Good information and will be sharing this with my Power students.
