Posted: 2023-03-20 01:38 AM
How to calculate fault level for generator source? What all technical parameters required for the same?
Posted: 2023-09-23 07:11 AM
To calculate fault level for a generator source, you'll need to consider several technical parameters. These include:
Generator Rating (MVA or kVA): This is the capacity of the generator.
Generator Impedance (in per unit): It represents the internal impedance of the generator and can be obtained from the manufacturer's data.
Short-Circuit Time (in seconds): The time it takes for protective devices to clear a fault.
Short-Circuit Current (in kA): This depends on the generator's capacity, impedance, and the system voltage.
System Voltage (kV): The voltage at which the generator operates.
Transformer Impedance (if applicable): If there's a transformer between the generator and the fault point, its impedance needs to be considered.
Once you have these parameters, you can use various methods like the per-unit system or symmetrical components to calculate the fault level. Remember to consult with a qualified electrical engineer or use appropriate software for precise calculations.
