Error while updating firmware on EVlink Wallbox
  • Power Distribution IEC
  • Error while updating firmware on EVlink Wallbox
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EVlink Load Management System
andersL
Crewman andersL Crewman
Crewman
Posted: ‎2021-05-03 04:49 AM . Last Modified: ‎2021-05-03 06:06 AM
2654
Trying to update from FW 3101 to 3303 on a EVLINK Wallbox.
Have an issue when logging on to the wallbox via IP and browser, the page just refreshes and goes back to log in page. When doing the same via SBO Workstation, it works just fine. But the customer dont have access to SBO.
I thought the solution was to upgrade firmware.
Here Is the log from firmware upgrading:
1094 0 [INFO ] Extracting /tmp/r7_update_3.3.0.15_d4.epk into /tmp/tmp.GkJw36
1094 1 [INFO ] Filesystem Size Used Available Use% Mounted on
tmpfs 61.5M 14.5M 47.0M 24% /tmp
ubi0_0 35.9M 13.4M 20.6M 39% /mnt/datas
0. 0s [INFO ] step0a: already done
0. 0s [INFO ] step0b: already done
0. 0s [INFO ] step0c: already done
0. 0s [INFO ] step0d: already done
0. 1s [INFO ] step0d: done, will flash partition 7
0. 1s [INFO ] step1: Flash new BSPv5 : check partition (1)
0. 4s [INFO ] step1: Flash new BSPv5 required (3199567006 -ne 1350547241)
0. 4s [INFO ] step1: Partition reflashed - trial 1, not verified yet
0. 4s [INFO ] step1: Flash new BSPv5 : check partition (2)
0. 7s [ERROR] Flash verification 3199567006 -ne 1350547241
0. 10s [INFO ] step1: Partition reflashed - trial 2, not verified yet
0. 41s [INFO ] step1: Flash new BSPv5 : check partition (3)
0. 44s [ERROR] Flash verification 3199567006 -ne 1350547241
0. 47s [INFO ] step1: Flash process failed after 3 trials
0. 47s [ERROR] step1.ckerr: Update ERROR: Flash verification failed for uImage.parkingboard_v2_1
0. 53s [INFO ] SOS 4 flashes every 10 s during 300 s
0.530s [INFO ] step1: Force reboot: stop busybox watchdog + reboot
1094 544 [ERROR] KO, ret=1
Somebody got an fix for this?
  • eMobility
  • evlink
  • fw
  • sbo
Louis_LEVEQUE
Lieutenant JG Louis_LEVEQUE Lieutenant JG
Lieutenant JG
Posted: ‎2021-05-03 12:50 PM . Last Modified: ‎2021-05-03 12:51 PM
You can't install directly the latest firmware.
  1. You have to install first the R6 firmware : https://download.schneider-electric.com/files?p_enDocType=Software+-+Hotfix+%26+Patch&p_File_Name=EV...
  2. Reboot
  3. And after install the latest firmware R7 : https://download.schneider-electric.com/files?p_Archive_Name=MFR4341700.zip&p_enDocType=Software%20-...
  4. Reboot
Best Regards
Louis
Louis_LEVEQUE
Lieutenant JG
  2. Reboot
  4. Reboot
Best Regards
Louis
