Error - System Out of Memory Exception
  • Power Distribution IEC
  • Error - System Out of Memory Exception
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
75
J_Travostino
Sisko J_Travostino Sisko
70
S-W
Commander S-W Commander
67
CVSD
Crewman CVSD
Crewman
Posted: ‎2022-09-07 07:57 PM . Last Modified: ‎2024-11-22 04:25 AM
4275
Hi All,
I have updated to newest version (v4.9.8 INT) and I am trying to fix selectivity issues in my network but I am facing system out of memory exception error. Any idea how to solve it? Please see picture attached for reference.
  • Power Distribution Software
Karthikeyan1
Lieutenant JG Karthikeyan1 Lieutenant JG
Lieutenant JG
Posted: ‎2023-04-24 01:11 AM
In the latest INT 5.0.0 version, the system out-of-memory exception issue is resolved.
Kindly use the latest version.
Thanks & Regards,
Ecodial Experts team.
Replies 5
Genghiz
Captain
Posted: ‎2022-09-07 09:42 PM
4265
Thanks for reaching this forum.
The situation that you are facing is understood.
To do a further analysis of this, can you please kindly share with us the following information.
  • The project file (.eac), that you have created using the EcoStruxure Power Design – Ecodial application.
  • If possible, the system information’s
    • The processor
    • Installed RAM
Thanks, and regards
Team – Ecodial Expert Support
CVSD
Crewman CVSD
Crewman
Posted: ‎2022-09-07 10:58 PM
In response to Genghiz
4262
Hi @Genghiz,
See below and attached:
  1. Processor: Intel(R) Core(TM) i7-10510U CPU @ 1.80GHz, 2304 Mhz, 4 Core(s), 8 Logical Processor(s)
  2. Installed Physical Memory (RAM): 32.0 GB
Goulamina Camp.zip
CVSD
Crewman CVSD
Crewman
Posted: ‎2022-09-08 01:08 AM
In response to CVSD
4254
Hi @Genghiz,
I am done with all warnings (selectivity issues) in my network and my guess was because I did the breaker selection more than one then pressed calculate project. When I tried to select the breaker one by one (select one breaker and calculated the project, it was fine without the error). Maybe you can verify this.
Karthikeyan1
Lieutenant JG
Posted: ‎2022-09-08 01:43 AM
In response to CVSD
It is good to know that your issue got resolved.
We are constantly working on resolving the Out of memory exception.
In the upcoming next release, this issue will be completely fixed and the user can use a bigger network also.
Thanks & Regards,
Karthikeyan1
Lieutenant JG
Thanks & Regards,
