Electrical calculation tool in TN-C Earthing
  • Power Distribution IEC
  • Electrical calculation tool in TN-C Earthing
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
mmiacca1
mmiacca1 Cadet | EcoXpert Master
Posted: ‎2024-09-23 10:54 AM . Last Modified: ‎2024-11-22 04:25 AM
897
When i calculate cross section area and change the earthing to TN-C the wire section is calculated with errors, check a 10 KW motor with 10 meters
  • Power Distribution Software
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2024-09-23 10:00 PM
Hi Mmiacca1,
Thanks for reaching us
Please share the details of errors and below mentioned datas to analyze the issue.
1.Frequency (Hz)
2.Phase to phase voltage (V)
3.System Earthing Arrangement- TN-C as you mentioned.
4.Max. permissible CSA (mm²)
5.Max Δu (%)
6.Number and type of load conductors.
7.Sr (kVA) / Pr (kW) / Ir (A)- 10KW as you mentioned.
8.Power factor
9.Live conductors
10.Active/PE conductor metal.
Thanks & Regards,
Team -Ecodial/ECT experts.
Saravanakumar.L
Lieutenant
Hi Mmiacca1,
1.Frequency (Hz)
5.Max Δu (%)
8.Power factor
9.Live conductors
Thanks & Regards,
Genghiz
Captain
Posted: ‎2024-09-26 02:32 AM . Last Modified: ‎2024-09-26 02:32 AM
Hello
The right inputs to reproduce your scenario is not clear.
The application is working as expected for the TN-C earthing system and sizing the conductors as expected. Following are some scenarios verified by our team.
Kindly please come back, if you have any specific scenario with different inputs.
Team – Ecodial Expert Support.
