Posted: 2023-10-27 06:36 AM
has enyone experienced problems with the latest version of Ecostruxure power commissioning?
When connected to NSX (OK), it is possible to "write to project" successfully, and when writing new setings, it says "Writing to device successful". But nothing happens in the device values pane.
Even though you type inn any password, it says "Writing to device successful"
When trying a different computer with old versjon of EPC, it works great.
This EPC version is no good!
BR
GIA
Posted: 2024-01-31 11:51 PM
Hello
Can you shared the version used and did you tested with the last version V2.30 ?
If yes and the issue is continuing, could you contact your local support to share the probleme and provide the log files of the software
Posted: 2023-11-29 05:17 AM
Same problem here. With each new EPC reversion, they fix one thing and brake something else that worked before. It's a huge waste of time.
J_GRT
Hello
