Ecostruxure Power Commission - Node UI Server is not running
  • Power Distribution IEC
  • Ecostruxure Power Commission - Node UI Server is not running
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Commission
AlexanderLotz
Lieutenant JG AlexanderLotz Lieutenant JG
Lieutenant JG
Posted: ‎2020-11-10 08:51 AM
14064
Dear Community,
one of our customers get the error "Node UI server is not running (as shown in screenshot). Please try again" when trying to open EcoStruxure Power (EPC) Commissioning Software. I know this error may occur when EPC and PME are is installed on the same machine which is not the case here. May there also be a problem with other SE software products vs. Ecostruxure Power Commission?
Best regards,
Alex
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2020-11-16 02:09 AM
20
14027
Hello
That issue occurs when EPC services are not started on application launch and required manual services restart.
There are 2 ways to do it :
Restart below 2 services manually from PC,
open "Services" application from Windows and stop / restart the both Ecoreach services :
  • Schneider Ecoreach node service
  • Schneider Ecoreach Service
Or Use the attached EcoreachServices utility (zip file) to restart services
Short instruction to run the EPC services restart utility:-
  • Download/save the EcoreachServices zip to PC
  • Unzip EcoreachServices.zip to EcoreachServices.exe
  • Run the EcoreachServices.exe with admin privilege
  • Launch EPC
EPC_Leader
Lt. Commander
Posted: ‎2021-10-07 05:50 AM . Last Modified: ‎2021-10-07 08:01 AM
In response to Sathees
7
12511
Hello @Sathees
You should have perhaps an issue with the EcoStruxure Power Commission installation in the computer. Please try to uninstall the soft and install it again
If you won't have success, I advice you to contact our local Schneider technical support or go through the technical support access link below :
https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp)
Best Regards
  • EcoStruxure Power Commission
EPC_Leader
Lt. Commander
Posted: ‎2022-02-16 05:52 AM
In response to AndreasMeier
Hi Andreas
You are facing an issue with the windows version or your computer settings ( firewall ,.... ). To solve the issue we need to have the log file recorded during the software starting. You could get the log file in the following path :
C:\Users\SESAXXXX\AppData\Roaming\Schneider-Electric\Ecoreach\Logs
To provide us the file, I advice you to contact your local Schneider technical support or go through the technical support access link below :
Best Regards
Replies 21
EPC_Leader
Lt. Commander
20
14028
Hello
  • Launch EPC
J_Travostino
Sisko
Posted: ‎2020-11-16 02:16 AM
In response to EPC_Leader
Many thanks @EPC_Leader for sharing.
Thanks a lot also to @Brundha for your great support.
@AlexanderLotz
Let us know the results.
Julien Travostino
Power Distribution & Digital forum community owner
Power Products Div.
AlexanderLotz
Lieutenant JG
Posted: ‎2020-11-17 01:08 AM
10
14017
Dear @EPC_Leader and @J_Travostino  thank you very much for your support.
Restarting the services solved the problem. 🙂
Best regards,
Alex
J_Travostino
Sisko
Posted: ‎2020-11-30 09:41 AM
In response to AlexanderLotz
9
13833
Great news @AlexanderLotz !!
Do not hesitate to come back to the Exchange community in any case 😉
Julien Travostino
Power Products Div.
Sathees
Ensign Sathees Ensign
Ensign
Posted: ‎2021-10-06 07:26 AM
In response to J_Travostino
12536
I couldn't open EPC software in one of the customer machine after installation, message was same "Node UI Server is not running. Please try again"
I followed same steps as you mention before but I could not find those services in windows services. Any reason why I can't find those services or will it not work in customer machine?
I installed EPC -V2.21.0
Regards
Sathees Project Engineer
EPC_Leader
Lt. Commander
7
12512
Hello @Sathees
Best Regards
Sathees
Ensign
Posted: ‎2021-10-07 08:09 AM
Issue is due to compatible issue. Apparently EPC doesn't work in server.
Kind Regards
Sathees
Posted: ‎2021-11-11 06:49 AM
5
12004
Thank you very much for your support....
In my case it was just a wrong installation. I did it again with "repair" option and it works correctly.
Regards
Erwin-vd-Zwart
Janeway
Posted: ‎2021-11-24 01:58 PM
In response to Anonymous user
11795
I have the same with a fresh install of EPC 2.22, but the strange thing is, i don't have the Ecoreach services as mentioned above to restart, I have re-installed, repaired, installed on VM, installed on fresh VM, installed on another laptop, all with the same result / Node UI error, so i guess the distribution 2.22 is causing this.. What can i do to solve this?
EPC_Leader
Lt. Commander
Posted: ‎2021-11-24 11:09 PM . Last Modified: ‎2021-11-25 01:20 AM
In response to Erwin-vd-Zwart
11788
Hello @Erwin-vd-Zwart
Which version of windows do you use in your computers ?
AndreasMeier
Ensign AndreasMeier Ensign
Ensign
Posted: ‎2022-02-15 11:50 AM
11072
Hi @EPC_Leader,
I have a similar/same issue as the post before that seem unresolved.
I'm trying to install EcoStruxure Power Commission in Version 2.23.0 on Windows 10 Enterprise (64-bit, 20H2), a parallel installation on Windows 10 Enterprise (64-bit; 21H1) has the same issues.
The installation is run "As Administrator" in both cases and the installation runs smoothly in both machines and with no apparent error messages. Both in common is, when trying to start EPC, the same error message is shown "Node UI server...." Checking the services list on both none of the previously shown services is available in the list. Repairing, uninstalling and reinstalling does not make any difference on any of the two machines.
After a couple of trying reinstalling a got a glimpse fo a second view on the command line windows after a restart of the machines and one of these windows having something that might have been an error message say like "path invalid", it was too short to get a full view on the cmd-line output.
Both computers in common (one is physical the other of VMWare Workstation VM) is that they are default Schneider Electric Windows installation images with all the security stuff to it.
Any ideas how to resolve the issue?
EPC_Leader
Lt. Commander
Hi Andreas
Best Regards
Posted: ‎2022-07-28 05:01 AM
I had the same issue - NodeUI Service error and the services missing from the services list - I tried uninstalling and reinstalling and on other machines.
Ultimately it turns out that the cause was due to not having Google Chrome installed. I found this in the log file at this location:
%USERPROFILE%\AppData\Roaming\Schneider-Electric\Ecoreach\Logs - within the EPCLaunchLog.txt.
It clearly states: EPC start failed ReasonWhyLanuchFailed = CHROME_NOTINSTALL
After installing Chrome everything worked as expected. (No idea why the app cannot just state the issue is a lack of Chrome, although I accept they recommend installing Chrome during installation)
Posted: ‎2022-10-25 01:00 PM
8333
I tried to stop / restart services, I tried the ecoreachservices tool, I tried to repair and restart, ... looks like nothing is working. I still have the same msg. What's the solution ? OS is Windows 10 Family Version 21H1
Posted: ‎2022-11-03 11:57 PM
2
8169
Same issue here.
I tried to stop / restart services, I tried the ecoreachservices tool, I tried to repair and restart, ... looks like nothing is working. I still have the same msg. We tested it on a Win10 and win11 machine, we even installed it on a planin virtual machine, nothing works.
EPC_Leader
Lt. Commander
Posted: ‎2022-11-04 12:13 AM
8163
Hello
In addition, EPC doesn't work in a virtual machine environement.
and we need the version of EPC that you try to install
Best Regards
  • teechnical issue
Posted: ‎2022-11-04 04:07 AM
that dosn't fix the issue at all.
It seems that schneider made a product who is barly supportet and has many issues.
By using it to monitor energiflow in a building we tried schneider, a desission we know regert.
Even the installation is quite simple to do, the over all experience is all but great. The Hardware Poertag LInk HD crashes or isn't reachable, the softare to configure dosn't work any when requesting support the answer is always to send a logfile.  Maybe it's a issue only win10User have, maybe Win11.
Posted: ‎2022-11-04 05:18 AM
Lovely automatic message…
Anyway, it looks like EPC is not compatible with my OS
Posted: ‎2022-11-05 02:45 PM
8111
Have you checked that the Chrome Browser is installed on your machine (Edge which also is based on Chromium is not adequate - it appears it has to see Google Chrome on the machine)
Posted: ‎2022-11-07 01:08 AM
8087
Hy,
Yes, i checked, Chrome is installed.
The Logfile Error Report says that the Modbus Driver is not installed and that the QRcode Scanner driver is not installed.
I have not found the two Plugins / Software for download.
Still waiting for a respond from schneider
EPC_Leader
Lt. Commander
Posted: ‎2022-11-07 01:21 AM
Hello
I would like to inform you that EcoStruxure Power Commission can now be installed and run without Google
Chrome since the v2.25 and more
  • teechnical issue
