Ecostruxure Power Commission Error
  • Power Distribution IEC
  • Ecostruxure Power Commission Error
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Commission
randypanaligan
Ensign randypanaligan Ensign
Ensign
Posted: ‎2021-05-26 04:37 AM . Last Modified: ‎2021-06-15 09:04 AM
6211
I would like to ask the community if you encounter the same error. I am installing the new version of Ecostruxure Power Commission version 2_20.1. When I first encounter this error. I have attached the file showing the error. During installation and once I started the application.
I did several time of unistalling it and reinstalling it. But the same outcome.
I did try also to used the different version but still the same issue. (Version 2.17)
Please advise.
  • Connectivity
  • How to
  • Software
  • ecoreach
  • ecostruxure
  • Modbus driver
  • power commission
adityachangi
Ensign adityachangi Ensign
Ensign
Posted: ‎2021-05-26 09:09 AM
2
6189
This is a problem with the Modbus driver installer.
Please use the latest installer released by Modbus team here: http://bricks-portal.schneider-electric.com/Domain/SW%20Device%20Platform/Domain/SW%20Device%20Platf...
Then EPC should launch fine.
randypanaligan
Ensign
Posted: ‎2021-05-26 07:29 PM
In response to adityachangi
Thanks for download link that you have given.
Here's the procedure on how it resolved.
1. Download modbus driver installer.
2. Run EcoStruxurePowerCommission V2.20.1.exe
3. Once the error on the modbus driver appear.
4. Run SchneiderModbusDriverSuite.exe recently downloaded.
5. Continue with the installation and follow the restart process.
6. After the installation, open Ecostruxure Power Commissioning Apps.
Replies 4
Fabien_Mastrot
Fabien_Mastrot Schneider Alumni (Retired)
Posted: ‎2021-05-26 08:51 AM
we will check with our experts to reply to you asap.
Rgds
Fabien
Fabien Mastrot
EcoXpert global badge owner
adityachangi
Ensign
2
6190
randypanaligan
Ensign
ovaldez
Crewman ovaldez
Crewman
Posted: ‎2024-04-16 09:45 AM
