Ecostruxre Power Commission 2.26 Error Unautharized
  • Power Distribution IEC
  • Ecostruxre Power Commission 2.26 Error Unautharized
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Commission
MajaStar
Lieutenant | EcoXpert Master MajaStar Lieutenant | EcoXpert Master
Posted: ‎2022-11-30 07:01 PM
2189
I've installed Ecostruxre Power Commission 2.26 and am having two issues. I can login, running the app as administartor, after a computer reboot. If I then close the app and open it again it it hangs on the start page flashing a red error unauthorized. If I reboot my computer it logs in fine. However once I login, I try to manually add a device which it can discover fine but then crashes on addding flashing again unauthorized.
Any help appreciated.
  • EcoStruxure Power Commission (EPC)
EPC_Leader
Lt. Commander EPC_Leader Lt. Commander
Lt. Commander
Posted: ‎2022-11-30 11:32 PM
2179
Hello
Could you provide  the Windows version used ?
In addition, I advice you to contact your local Customer care center to have a deeper analysis of the issue
UdhayakumarAK
Commander UdhayakumarAK Commander
Commander
Posted: ‎2022-11-30 11:45 PM
2174
Hello @MajaStar
Please attach EPC logs as well while contacting customer support.
Thanks!
Regards
Udhayakumar A K
ESXP System Support Expert
MajaStar
Posted: ‎2022-12-01 12:53 PM
In response to UdhayakumarAK
Thanks very much for replying.
Attached are the logs.
Kind Regards,
EcoStruxurePowerCommission_Logs.zip
Replies 4
EPC_Leader
Lt. Commander
2180
Hello
UdhayakumarAK
Commander
2175
Hello @MajaStar
Thanks!
Regards
Udhayakumar A K
MajaStar
Posted: ‎2022-12-01 12:50 PM
In response to EPC_Leader
Thanks for your response, I will contact local support also.
My Windows version is Windows 10 Pro.
MajaStar
Kind Regards,
