Ecodial basic calculation
  • Power Distribution IEC
  • Ecodial basic calculation
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
J_Travostino
Sisko J_Travostino Sisko
70
S-W
Commander S-W Commander
67
WinNer
WinNer
Cadet
Posted: ‎2025-07-02 12:11 PM
113
I'm new to Ecodial.
I started with a basic calculation and got these alerts.
2.5 mm² should be fine.
The alerts disappear at 10 mm², but that doesn't make sense.
What am I doing wrong?
  • How to
  • Software
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-07-10 01:52 AM
Hello @WinNer, thank you for your post!
@Saravanakumar.L, can you advise @WinNer please?
Thank you in advance 🙂
Darini
Crewman Darini Crewman
Crewman
Posted: ‎2025-07-31 12:40 AM . Last Modified: ‎2025-07-31 12:41 AM
hi @WinNer thanks for your question.
Why it works with 10 mm²:
At 10 mm², the ampacity (current-carrying capacity) of the cable is high enough to handle the load with the derating factors applied due to the installation method, ambient temperature, and grouping.
In simple terms:
Even though 2.5 mm² might normally be okay in open air, inside a duct or tray (Method B) with other cables, heat buildup, or high current, it’s not.
 How to fix it:
Here are your options:
1. Change installation method
• Go to the cable properties in Ecodial
• Set it to Installation Method C (clipped direct on a wall) or another method with better heat dissipation
2. Check the current level
• If your load is too high for 2.5 mm², either reduce the load or split it.
• If multiple cables are run together, they need derating. You can reduce the number of cables grouped together or improve spacing.
4. Increase cable size (which you already tried)
• Going to 6 or 10 mm² works because those cables can handle more current.
Basically,in Ecodial, alerts are strict because it uses IEC 60364-based ampacity tables with derating. Always consider:
• Cable material (Cu/Al)
• Installation method (A, B, C, D, etc.)
• Ambient temp, grouping, and insulation type
Hope that answers your question! 😄
This is a heading
