Ecodial. Default phase connection for 1-phase load
  • Power Distribution IEC
  • Ecodial. Default phase connection for 1-phase load
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
AndrejsRo
Crewman AndrejsRo Crewman
Crewman
Posted: ‎2025-03-14 10:13 AM
1070
questions for the Ecodial developers.
Is it possible to make a little improvement of the software?
Problem:
When I placing and coping a single-phase load, connection parameter always switching to "L1-N".
Too many loads can be mistakenly connected to L1..
Solution:
Set connection parameter as "Automatic" by default (instead of L1-N)
Thanks in advance!
  • India Power Distribution & Digital
Saravanakumar.L
Lieutenant Saravanakumar.L Lieutenant
Lieutenant
Posted: ‎2025-03-18 03:37 AM
1001
Hello AndrejsRo,
Thanks for reaching us!
We have validated your query and got to know that in the project. if we set the single-phase load and coping the same load and install Ecodial automatically changing the Phases from L1 to L3 alternatively for maintaining the phase balance.
This is the normal behavior of Ecodial as expected.
Please find the attached video for your ready reference.
Thanks & Regards,
Team- Ecodial expert support.
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-03-17 12:54 AM
Hello @AndrejsRo, thank you for your post!
@Saravanakumar.L, can you advise @AndrejsRo please?
Thank you in advance!
Saravanakumar.L
Lieutenant
1002
Hello AndrejsRo,
Thanks & Regards,
AndrejsRo
Crewman
Posted: ‎2025-03-19 06:29 AM
In response to Saravanakumar.L
Hi, thank you for explanation.
Yes, Ecodial behaves as you described.
As well I found out, that when load power (kW) not specified (circuits are in blue color), in that case, when coping, Ecodial always switching to L1.
Best regards, have a good day.
