EcoStruxure Power Design - Ecodial INT 4.9.7 - The CIRCUIT NAME is now as part of the Data Table and Solution Table
Send InviteCancel
Posted: 2021-09-1412:13 AM. Last Modified: 2024-11-2204:25 AM
The CIRCUIT NAME is now as part of the Data Table and Solution Table.
Draw the electrical network, on the Ecodial application (at the Design & Sizing Tab) as per the requirements.
Provide all the necessary inputs to the loads and circuits.
DATA TABLE can also be used to provide inputs for the “components like Cable, load, protection and so on.”
Calculate the project as usual.
Once after the successful completion of the project calculation; As part of the report generation, please click on the SOLUTION TABLE.
We can see the component results (solutions) are grouped as per their CIRCUIT NAME.
Data Table - Cable component association with Circuit Name
Additional Benefit:
All the content of the Data Table & Solution Table can be exported in EXCEL, and they can be easily recognized as per the associated “CIRCUIT NAME” and using their “COMPONENT NAME.”
