EcoStruxure Power Commission Software version (2.35.0) Error Microsoft Visual C++ 2013 Redistributable (x86)
  • Power Distribution IEC
  • EcoStruxure Power Commission Software version (2.35.0) Error Microsoft Visual C++ 2013 Redistributable (x86)
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
EcoStruxure™ Power Commission
ingenidiaz
ingenidiaz
Cadet
Posted: ‎2025-04-28 12:30 AM
943
I wanted to ask the community if someone have had this issues when installing the EcoStruxure Power Commission Software version (2.35.0). When trying to install this software, I get the following message: “The files required for the installation of Microsoft Visual C++ 2013 Redistributable (x86) have not been found. The installation will stop. This is probably due to a failed or cancelled download". I have tried separately and manually to install Microsoft Visual C++ 2013 Redistributable (x86), it installs it correctly but the error persists.
I have read in this forum that it could be a Schneider Modbus Driver problem, I have installed separately the Schneider Electric Modbus Driver Suite V14.13.0.0 version; and the problem remains. Has anyone had the same problem? Can someone please help me with a solution? Thanks.
@adityachangi  @randypanaligan
  • EcoStruxure Power Commission (EPC)
Jibin_SAM
Ensign Jibin_SAM Ensign
Ensign
Posted: ‎2025-06-10 11:30 PM
Hi @ingenidiaz  ,
Try to get the full admin rights for the installation. This ensures it can access system folders and registry keys
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-04-28 04:59 AM
Hello @ingenidiaz, thank you for your post!
@EPC_Leader can you please advise @ingenidiaz ? Thank you in advance!
Jibin_SAM
Ensign
Hi @ingenidiaz  ,
