Early detection of overheated cables? Check how PowerLogic HeatTag helps to make it...
Showing results forΒ
Did you mean:Β
  • Power Distribution IEC
  • Early detection of overheated cables? Check how PowerLogic HeatTag helps to make it...
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
  • Comunidade de SoluΓ§Γ΅es ElΓ©tricas
PowerLogic HeatTag
Vassiliki_NOTI
Lieutenant JG Vassiliki_NOTI Lieutenant JG
Lieutenant JG
Posted: β€Ž2021-02-12 03:07 AM . Last Modified: β€Ž2021-02-12 05:05 AM
12
5633
Did you know that...
For more than 20% of fire incidents in facilities, the origin is in the electrical equipment.
Among the top causes?
Overheated cables & poor wire connections.
A reactive response to a fire, can potentially limit the damage and the cost consequences in a facility.
But is it indeed enough to be on the reactive side?!?!?
πŸ€”πŸ€”πŸ€” What if, we could monitor 24/7 the cables in electrical distribution switchboards and be alerted early enough, having the time to act, before smoke appears or an electrical fire starts?
The innovative #PowerLogicHeatTag sensor comes to meet the challenge, bringing the #ElectricalFirePrevention to the next level.
PowerLogic HeatTagPowerLogic HeatTag
The new smart sensor PowerLogic HeatTag by analyzing gasses and microparticles inside the switchboard, is able to detect in a very early stage overheated cables and alert the operator that he needs to take an action on time...and this is...prevention...fire prevention...Electrical Fire Prevention!
Join me, to find out more on how PowerLogic HeatTag wireless sensor can help to improve our safety, by watching the video and share with us your feedback πŸ˜‰
Vassiliki NOTI
Marketing Offer Range Manager
Power Products Division
Energy Management Business
  • Connectivity
  • Products
  • Safety - Electrical Fire Prevention
  • connectivity
  • Electrical fire prevention
  • Fire prevention
  • HeatTag
  • powerlogic
  • PowerLogic HeatTag
  • PowerTag System
  • Prevention
Vassiliki_NOTI
Lieutenant JG
Posted: β€Ž2021-02-12 06:14 AM
In response to L_Valentin
1
5618
Hello @L_Valentin,
thanks for your message πŸ™‚
Yes, PowerLogic HeatTag is already integrated in some of our softwares and thoughout the year there will be a full integration.
What is available today:
Gateway : PowerTag Link firmware V002.000.004
PowerTag Link firmware upgrade:  available through EcoStruxure Power Commission V2.19
Communication: Modbus TCP/IP
Integration in softwares through Modbus register table
Stay tuned...PowerLogic HeatTag integration is loading...follow us to get updates when a new release is On πŸ˜‰
Vassiliki NOTI
Vassiliki_NOTI
Lieutenant JG
Posted: β€Ž2021-03-02 10:50 AM
In response to Anonymous user
6
5428
Hello @Anonymous user ,
PowerLogic HeatTag became recently commercial. Progressively within the coming months will become available in all EU countries. We would suggest you to get in contact with your country local Schneider Electric and check the status of offer availability.
Vassiliki NOTI
Vassiliki_NOTI
Lieutenant JG
Posted: β€Ž2021-03-10 01:31 PM
1
5308
In case of shut down: at first HeatTag has no integrated memory, so no historical data are kept at the level of HeatTag device. Sensor mission is 24/7 real time monitoring and alert the user early enough that has detected overheated cable(s) inside electrical cabinet.
History is recorded at the level of relevant Gateway and Software depending on their capabilities. Concenring HeatTag in the case of shut down, what maybe could be considered as possible constraint, would be to have the sensor unpaired from the gateway, but it is not the case.
Once the HeatTag is paired with the gateway then unpairing cases (which means that pairing will need to be re-established) could be:
a) HeatTag device has been resetted to factory settings
b) Loss of communication between HeatTag and Gateway for more than 15min will require unpairing and pair again (loss of communication in terms of network, not power supply)
If the connection between HeatTag and Gateway is established once then remains when switching off and powering on again the device.
Related to UPS for HeatTag power supply: sensor monitoring has a meaning when there is power in the electrical cabinet/panel and potentially we might face cables overheating incident. If no power > no potential overheating > nothing for HeatTag to detect. Having said that, UPS is not required for power supply (it is not forbidden if already exists, but not required for sure).
What maybe would be interesting at this point to share with you is that during the first 30 minutes after switching on the HeatTag sensor, the device is in test mode, that is , the HeatTag sensor can trigger an overheating alert for test by using the HeatTag Tester or any other alert requested by Panel Server or gateway remotely. It takes another 8 hours for the HeatTag sensor to define its nominal environment (learning phase, however sensor able to give alert in the case of cable overheating incident) and to be fully operational. Each time the HeatTag sensor is powered on, 30 minutes and 8 hours sequences are repeated.
Feel free to find out more details in:
  • PowerLogic HeatTag Web Page
  • PowerLogic HeatTag Technical Datasheet
  • PowerLogic HeatTag User Guide
  • PowerLogic HeatTag Instruction Sheet
Hope I have managed to provide the required information (and hopefully not confuse you 😊).
Let me know if it is ok for you or you would need some more clarifications.
Vassiliki NOTI
Replies 12
L_Valentin
Lt. Commander L_Valentin
Lt. Commander
Posted: β€Ž2021-02-12 05:18 AM
2
5621
Hello @Vassiliki_NOTI
Thank you for this very useful and interesting information.
I still have some questions : How is your new sensor linked with the existing software ?
As example : Is it integrated into your Ecostruxure Power Commission ? Or Power Monitoring Expert software ? etc..
Will the users need to buy a new module for these softwares ?
Thank you in advance.
Vassiliki_NOTI
Lieutenant JG
1
5619
Hello @L_Valentin,
Vassiliki NOTI
L_Valentin
Lt. Commander
Posted: β€Ž2021-02-14 11:25 PM
In response to Vassiliki_NOTI
@Vassiliki_NOTI
thanks a lot for your quick answer.
it is clear.
SebTTG
Lieutenant SebTTG Lieutenant
Lieutenant
Posted: β€Ž2021-02-24 01:24 AM
Great sharing ! Thanks
STT - EcoXpert LV & MV badge owner
Posted: β€Ž2021-02-26 05:18 AM
7
5443
Hello
Really geat idea. Is it available in Europe Distributors ?
Vassiliki_NOTI
Lieutenant JG
6
5429
Vassiliki NOTI
Posted: β€Ž2021-03-03 04:42 AM
Really innovative solution for Preventing Fire incidents in the world!
Posted: β€Ž2021-03-05 05:31 AM
4
5358
Sorry . I forgot to thanks you for the answer. Really great idea.
It embedds is own battery in case of shunt down ?
Vassiliki_NOTI
Lieutenant JG
Posted: β€Ž2021-03-05 05:45 AM . Last Modified: β€Ž2021-03-05 05:54 AM
3
5355
no worries at all πŸ˜Š
Concerning HeatTag and shut downs:
PowerLogic HeatTag is not battery dependent, actually requires single phase power supply (110 to 277VAC) and to be protected as device (like all control devices) by a 2A mcb curve C or fast acting fuse.
There is a tolerance Β±15% for voltage fluctuations and up to 20ms for spontaneous outages.
Hope it helps πŸ˜‰
Vassiliki NOTI
Posted: β€Ž2021-03-10 08:27 AM
2
5318
Thanks Miss Noti.
Interesting answer. But not enough specific for me. Does it mean it requires a small UPS in the Power supply of the Heattag ?  In case of shunt down, it will lose all his data, configuration ?.
Hope my quesytion is clear.
Vassiliki_NOTI
Lieutenant JG
1
5309
Vassiliki NOTI
Posted: β€Ž2021-03-12 07:00 AM
Thank you. Really clear.
Β
