EVLink Pro AC Not Starting Correctly - White Status Indicator
  • Power Distribution IEC
  • EVLink Pro AC Not Starting Correctly - White Status Indicator
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
CamboHeath
Lieutenant | EcoXpert Master CamboHeath Lieutenant | EcoXpert Master
Posted: ‎2025-03-24 08:52 PM
1209
Hi there,
We have a number of EVLink Pro AC chargers installed on a customer site.
The customer has reported a failure where one of the chargers no longer functions. The Status LED along the top is white for 60s before turning off and then going white again, as if stuck in some kind of boot loop. It is not possible to establish communications to the device.
We have tried a factory reset using the 5th and 6th micro-switch per the installation manual to no effect.
The "Status Indicator Light" section of the EVlink Pro AC Charging Station Troubleshooting Guide (DOCA0282EN-00) makes no mention of a White LED colour, and indicates an error state should be a red LED. I have seen the LED go white during firmware upgrades during normal operation, but this is not stated in the troubleshooting guide either.
Has anyone in the community encountered anything similar? Is this a known issue with a resolution, or is the unit faulty and will require replacement?
Thank you
  • eMobility
Louis_LEVEQUE
Lieutenant JG Louis_LEVEQUE Lieutenant JG
Lieutenant JG
Posted: ‎2025-10-27 02:57 AM
Hello
1.3.6 have an issue which can cause reboot in loop white for 40 s - off for 0.5 s in loop.
You must update the FW if it is currently in 1.3.6.
The local customer care center have the information, do not hesitate to call them when you have an issue :
https://www.se.com/ww/en/work/support/country-selector/contact-us.jsp
Replies 5
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-03-25 12:36 AM . Last Modified: ‎2025-03-25 12:38 AM
Hello @CamboHeath, thank you for your post, we'll come back to you!
@Louis_LEVEQUE can you advise @CamboHeath please?
Thank you in advance :)!
Louis_LEVEQUE
Lieutenant JG
Posted: ‎2025-03-27 12:55 AM
Hello @Sagar_Modi
can you give an answer for @CamboHeath please ?
CamboHeath
Posted: ‎2025-03-27 03:00 PM
I will note that i believe this charger had firmware 1.3.6.
Anecdotally I have heard from Schneider support that firmware 1.3.6 is a FW version that causes Pro AC to crash permanently if left in that version too long.
Though, i haven't seen an official transmission from Schneider advising that this firmware is unstable.
Are other chargers on firmware 1.3.6 at risk of failure? And therefore does the full fleet of EV chargers need to be visited with a USB and firmware upgraded one by one?
EricAuto
EricAuto
Cadet
Posted: ‎2025-10-21 03:53 PM
Does someone have an update on this issue. We have a client that seems to have a similar issue where the status light is showing a white light. What does this mean? Is it stuck booting up like CamboHeath mentions?
The manual mentions the white light but nowhere says what to do or what it means.
Louis_LEVEQUE
Lieutenant JG
Hello
