Circuits of ASSEMBLIES which are exempted from the verification of the short-circuit withstand strength
  • Power Distribution IEC
  • Circuits of ASSEMBLIES which are exempted from the verification of the short-circuit withstand strength
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2019-06-19 08:57 AM . Last Modified: ‎2020-11-20 03:53 AM
4219
Could you please indicate in what cases circuits of Assemblies are exempted from the verification of the short-circuit withstand strength according to IEC 61439-1 and how we can apply this rule with limitor circuit-breaker ?
  • Connectivity
MathieuGuillot
Lieutenant MathieuGuillot Lieutenant
Lieutenant
Posted: ‎2019-07-02 05:27 AM . Last Modified: ‎2021-06-21 05:21 AM
Elina
The Clause 10.11.2 of IEC 61439-1 exempt from doing a short circuit test in two cases:
10.11.2 Circuits of ASSEMBLIES which are exempted from the verification of the short-circuit withstand strength
A verification of the short-circuit withstand strength is not required for the following:
1) ASSEMBLIES having a rated short-time withstand current (see 5.3.5) or rated conditional short-circuit current (see 5.3.6) not exceeding 10 kA r.m.s.
2) ASSEMBLIES protected by current-limiting devices having a cut-off current not exceeding 17 kA at the maximum allowable prospective short-circuit current at the terminals of the incoming circuit of the ASSEMBLY.
According to the second bullet, it’s possible to use the limitation characteristics of compact NSX & NSXm to avoid a short-circuit test for prospective short-circuit current that will be limited below 17kApeak
So the following values can be keep as a rule:
Incomer circuit-breaker
Icu (kA)
@415V
Maximum presumed short-circuit current in kArms where IEC 61439 sort-circuit withstand test is not required
(Clause 10.11.2 -2) with specified incomer : 415Vac 50Hz
Compact NSXm 160 E
16kA
16kA
Compact NSXm 160 B
25kA
25kA
Compact NSXm 160 F
36kA
36kA
Compact NSXm 160 N
50kA
50kA
Compact NSX100-160 B
25kA
25kA
Compact NSX100-160 F
36kA
36kA
Compact NSX250 B
25kA
25kA
Compact NSX250 F
36kA
30kA
Compact NSX400 F
36kA
15kA
Compact NSX630 F
36kA
12kA
Mathieu GUILLOT
LV Power circuit-breakers
MathieuGuillot
Lieutenant
Elina
Icu (kA)
@415V
Compact NSXm 160 E
16kA
16kA
Compact NSXm 160 B
25kA
25kA
Compact NSXm 160 F
36kA
36kA
Compact NSXm 160 N
50kA
50kA
25kA
25kA
36kA
36kA
Compact NSX250 B
25kA
25kA
Compact NSX250 F
36kA
30kA
Compact NSX400 F
36kA
15kA
Compact NSX630 F
36kA
12kA
Mathieu GUILLOT
