Checking Selectivity using EcoStruxure Power Design - Calculation Tools
  • Power Distribution IEC
  • Checking Selectivity using EcoStruxure Power Design - Calculation Tools
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Posted: ‎2020-11-30 01:50 AM . Last Modified: ‎2024-11-22 04:25 AM
If you have a combination of protection equipment for which you need to find the selectivity limits, look no further than the "Check Selectivity" feature of EcoStruxure Power Design - Calculation Tools.
Using the Check Selectivity feature, you can browse all the available protection devices(Circuit Breakers and Fuses) by their rating and other characteristics and quickly evaluate the selectivity limits. You can also check the selectivity limits for various protection setting combinations. You can also visualize the curves. To help you generate accurate documentation for your project, this feature lets you download the results of the tool in either PDF or DOC format.
You can access the application here
  • Power Distribution Software
Replies 0
