Case Study: Arc Flash Incident in a Medium Voltage Cubicle
Send InviteCancel
Posted: 2025-10-3105:21 AM. Last Modified: 2025-10-3105:22 AM
During the preparation phase of a retrofit project, an operator opened the door of a live medium voltage (MV) cubicle to take measurements. While working outside the enclosure, their tape measure accidentally slipped and fell inside, making contact with exposed conductors.
The result: A sudden arc flash occurred, causing severe burn injuries and significant equipment damage.
This incident highlights several critical risks:
Even indirect interaction with live equipment can trigger an arc flash.
Foreign objects, such as tools or loose components, can easily become ignition sources.
