Can someone explain electric utility distribution easily?
  • Power Distribution IEC
  • Can someone explain electric utility distribution easily?
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
labodd
labodd
Cadet
Posted: ‎2024-08-29 03:39 AM
793
I’m working in an electric utility as a civil engineer. I don’t have a good background in electrical and think it would be helpful if I understood it better. I work on the structures but I’d like to be able to understand what’s happening when I’m invited to meetings.
Can someone provide a simple explanation on how power distribution works?
Is it actual amperage that gets distributed? Is it watts?
How does the amount of power vary between a 25kV primary and a 120/240V secondary?
Also why is it 120/240V and not just 120V? Or just 240V?
I have lots of questions, anything helps!
omegle xender
  • How to
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2024-09-03 12:09 AM
Hello @labodd! 🙂
Power distribution involves the efficient and safe delivery of electrical power from generation sources to end users.
The distribution system typically starts with high-voltage transmission lines, which carry electricity from power plants to substations. At the substation, transformers reduce the voltage for safer distribution to homes and businesses.
In power distribution, amperage (measured in amps) and power (measured in watts) are crucial concepts. Amperage represents the amount of electrical current flowing through a circuit, while power (in watts) represents the actual energy consumed or used by devices. The relationship between them is defined by the formula:
**Power (in watts) = Voltage (in volts) x Current (in amps).**
For example, when comparing a 25 kV primary system to a 120/240V secondary system, the primary system operates at a much higher voltage, allowing for efficient transmission of power over long distances with lower energy losses. The 120/240V secondary system, however, is the standard voltage for residential and light commercial applications, providing the necessary voltage levels for common household appliances and devices. The 120/240V designation indicates a split-phase system commonly used in residential settings. In this system, 120V is used for most standard outlets and lower-power devices, while 240V is used for larger appliances, such as electric stoves and dryers. This split-phase design allows for a wider range of electrical devices to be powered within a home without requiring a completely separate wiring system for high-power appliances.
Manon_Chaboud
Commander
Hello @labodd! 🙂
