Cable termal constrait
  • Power Distribution IEC
  • Cable termal constrait
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
laumarher
laumarher
Cadet
Posted: ‎2025-09-19 12:21 AM
312
How to resolve that warning?:
"Cable termal constrait (i2t>k2s2) is exceded at 10 ms, please check if circuit breaker energy limitation curve validates k2s2<i2t for short circuit value, otherwise please increase cable cross section value oh [PH]"
I have tried increasing the cable section and it does not solve the problem.
I attach a file, thank you
Oficina_DNI_20250919.eac
  • How to
Darini
Lieutenant JG Darini Lieutenant JG
Lieutenant JG
Posted: ‎2025-10-30 10:27 PM
hi @laumarher  ,
thanks for the query!
this issue here is that Ecodial showed a “thermal constraint (I2t > k2S2) exceeded” warning for cables
This means that during a short-circuit, the energy passing through the cable (I2t) was higher than what the cable’s insulation and size could safely handle.
Reason:
The fault current at that point was around 12 kA, and the earlier cable size (1.5 – 10 sqmm) was too small to withstand that energy.
Workaround:
After increasing the cable size to 16 sqmm (Cu/PVC), the cable can now handle the short-circuit energy, and the warning is cleared.
so you might have tried to increase the CSA to 4 or 6sq.mm and that is not sufficient according to the constraints.
Hope that clarifies it for you!
Darini H.D
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-09-19 07:48 AM
Hello @laumarher, thank you for your post, we'll come back to you!
Sumit_Kumar
Sumit_Kumar Cadet
Cadet
Posted: ‎2025-10-30 08:59 PM
@Darini please have a look at it
Darini
Lieutenant JG
hi @laumarher  ,
Reason:
Workaround:
Darini H.D
