Breaker main terminal material
  • Power Distribution IEC
  • Breaker main terminal material
Genghiz
Captain Genghiz Captain
93
Gregoire_Brun
80
J_Travostino
Sisko J_Travostino Sisko
70
Mary
Mary
Cadet
Posted: ‎2025-02-25 04:42 PM
1020
Hello, I would like to inquire about the Circuit breaker Masterpact MTZ2 20H2, 2000 A terminal material.Can the main terminal be changed from copper material to tin plated material? Do you have this type of option (tin plated terminal)?
NeiB
Lt. Commander NeiB Lt. Commander
Lt. Commander
Posted: ‎2025-02-27 08:51 AM
1
996
Hi @Mary ,
Wish you are very well.
Sadly it is not possible to replace the copper terminals for the Aluminum (tin plated) ones as it is indicated on the document page 5/18 as follow. The probably reason is due to the high level of current those MTZ have to stand:
https://download.schneider-electric.com/files?p_enDocType=Instruction+sheet&p_File_Name=MTZ2-3_Power...
Best Regards,
Neide
Replies 4
Manon_Chaboud
Commander Manon_Chaboud Commander
Commander
Posted: ‎2025-02-27 12:35 AM
Hello @Mary, thank you for your post, we'll come back to you!
NeiB
Lt. Commander
1
997
Hi @Mary ,
Best Regards,
Neide
Mary
Mary
Cadet
Posted: ‎2025-02-27 06:12 PM
In response to NeiB
Hi Neide,
Thank you very much for your prompt response. Regarding the copper terminal, understood.
Gregoire_Brun
Commander
Posted: ‎2025-02-27 11:49 PM
hello @Mary
I'm completly aligned with @NeiB  and to complet her answer, Copper parts have a silver surface treatment.
Gregoire Brun
Breaker Product Expert
