Update Remote Device display
Pod sharing
Send InviteCancel
Configure the settings used for HTTP or HTTPS communication between the pod-sharing host and the remote devices.
Element
Description
Host/IP Address
Identify the hostname or IP address of the remote device that has pods you want it to share with the host NetBotz Appliance.
Port
Identify the port used for the communication: default is 80 for HTTP, and 443 for HTTPS.
SSL Options
Select how the Secure Sockets Layer (SSL) protocol will be used for the communication with the remote device: None, Require SSL - No verification, Require SSL - Verify certificate, or Require SSL - Verify certificate and hostname.
User ID
Type in the User ID to be used to access the remote device.
Note
Some remote pod functionality may be unavailable if the user ID is for a user account that does not have Administrator privileges.
Password
Type in the password to be used with the User ID to access the remote device.
Confirm Password
Retype the password.
Timeout (seconds)
Define how long, in seconds, the host NetBotz Appliance will wait for a response before it considers an attempt to communicate with a remote device has failed.
