- Als nieuw markeren
- Bladwijzer
- Abonneren
- Dempen
- Abonneren op RSS-feed
- Markeren
- Afdrukken
- Naar een vriend e-mailen
- Ongepaste inhoud melden
op 2023-11-23 08:22 AM
EcoStruxure Panelservers - nieuwe firmware 1.8
Beste Paneelbouw partners,
Er is een nieuwe firmware (versie 1.8) gekomen voor de Panelservers.
Deze firmware is voor de EcoStruxure Panel Server 400 / 600 en 800.
Belangrijkste nieuwe functies voor de PAS400 (Entry model)
Improvement in commissioning of wireless PowerTag Energy devices
Wireless PowerTag Control devices:
Full integration of following devices:
PowerTag C IO 230V digital input output module (A9XMC1D3)
PowerTag C 2DI 230V digital input module (A9XMC2D3)
Enable/disable local control from webpages
Data sampling: popup message is displayed in the webpages when number of sampled data of paired Modbus or wireless devices is close to 90% of or exceeds the system sampling limit. Recommended action is provided.
Webpage user experience improved:
Monitoring and Control menu: all digits of energy data values are displayed (scientific notation no longer used)
Belangrijkste nieuwe mogelijkheden in de 600 versie (Universal model)
Improvement of commissioning of Modbus devices to enable reading of Modbus-SL device registers through webpages
For devices connected downstream to an I/O Smart Link device:
Addition of the contextualization of the signal element for standard I/O devices
Support of predefined values in the contextualization of pulse counter devices
Modbus devices webpage: additionally displays name and version of custom model used
Custom device model: supports units defined in custom measurement in Panel Server webpages (for example, Modbus devices, Trending menu, Monitoring and Control menu)
NOTE: Units are not published to the Cloud. -
- PowerTag C 2DI 230V digital input module (A9XMC2D3)
Support of contactor with feedback loop configuration
Support of impulse relay configuration
For wireless devices: in the Wireless devices > Wireless discovery webpage
For Modbus devices in the Modbus addition webpage
Monitoring and Control menu: all digits of energy data values are displayed (scientific notation no longer used.
Belangrijkste nieuwe mogelijkheden in de 800 versie (Advanced model)
New Notifications page provides journal of alarms, for display only.
New functionalities provided in the Trending menu
Comparison mode is available in Aggregated view in addition to Device view.
Comparison mode supports comparison of integrated data (for example, active energy)
Trending menu
Same default periods in Trending and Home menus
Start time in a period is preserved when compare mode is activated or disabled
Curves or barcharts are displayed with background grid for better readability
Use buttons to select or deselect a curve or barchart in a graph
Direct access via icon to Trending - Aggregated view page from Home page
Zie voor de firmware release notes en firmware downloads:
Nieuwe Product Informatie
- Tags:
- english
Verificatie mislukt.
- Verificatietickets komen niet overeen. Verificatie mislukt.
- Bladwijzer
- Abonneren
- Dempen
- Markeren
- Afdrukken
op 2023-11-23 10:08 PM
bedankt voor de update Jun, ben benieuwd naar de commissioning van de powertags!
