Remove Thresholds from Notification Policy option
Navigation view
Send InviteCancel
This option allows you to remove thresholds for the selected device group or device from a policy used by the server to generate alarm notifications.
In the Alarm Configuration perspective, you can select device groups, devices, or thresholds and remove the thresholds for that selection from an existing notification policy. When one or more device groups or devices are selected, all the thresholds for that selection will be removed from the selected notification policy.
Two menus in the Alarm Configuration perspective provide access to the Remove Thresholds from Notification Policy option:
Right-click menu Remove Thresholds from Notification Policy in the Navigation view.
Right-click menu Remove Thresholds from Notification Policy in the Threshold Alarm Configuration view.
