Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Understanding Motion Control
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Understanding Motion Control
  • Subscribe to RSS Feed
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
lame153
lame153
Cadet
Posted: ‎2025-02-24 03:12 AM
244
Hey guys, I am a beginner in industry. And I am doing a little research on PLCs and Motion control etc… I am the type who likes to use analogy to better understand concepts. There’s a project where I will have to use a delta robot to which I want to continuously send a list of coordinates (from a python program) for objects to be picked (example: [{1,2},{2,2.5},{3,3.4}] is a list of x,y coordinates). The list is gonna be sent via some kind of communication. But once the list arrives to the motion control, the latter is gonna control the delta robot’s every movement to pick up the object.
The analogy (which I would like you to correct if wrong) is that PLC and motion control are two different hardwares that can control a system. But PLC differs from motion control the same way a digital pin differs from an analog pin on an arduino board. PLC is for boolean stuff (on/off) while MotionControl is for analog stuff (servo angle). As for both hardwares, they can be programmed using ladder language on the Codesys IDE (the equibalent of python language on the vscode IDE)
Am I thinking right so far?
omegle
  • Training and Education
Francesco_Begnoni
Support
Posted: ‎2025-02-25 02:16 AM
Hi @lame153 ,
Basically, what you wrote is correct. I would add that in Schneider Electric PLCs and controllers, which are based on Codesys, you can use both ladder programming and structured text programming. This allows you to develop a single program that can execute both logic and motion.
You can use various types of Ethernet-based communication. What you want to do is possible, to send a list of coordinates with a Python script directly to the PLC/controller via a TCP socket.
There are many libraries available that allow you to easily perform motion/robotics operations.
If you haven't already, you can consult Schneider's online help to get an idea -> Machine Expert > V2.2
Regards
Francesco_Begnoni
Support
Hi @lame153 ,
Regards
HKTAI
HKTAI
Cadet
Posted: ‎2025-04-30 05:21 AM
78
I also need this controller and Python libs. Which Schneider controller and lib can be used to meet this requirement? @Francesco_Begnoni @lame153
Francesco_Begnoni
Support
Posted: ‎2025-05-09 02:37 AM
In response to HKTAI
Hello @HKTAI
At this page you have an overview of which controllers can use the TcpUdpCommunication library:
Libraries Overview
Machine Expert has an example to create a TCP server: TCP & UDP Communication Example
You can use the following python script to connect to the controller and send a simple string:
#!/usr/bin/env python3
import socket
TCP_IP = '192.168.178.231'
TCP_PORT = 35274
BUFFER_SIZE = 1024
MESSAGE = "AAAABBBB"
# Create socket TCP
s = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
try:
    s.connect((TCP_IP, TCP_PORT))
    print('Connected to server')
    # Send MESSAGE
    s.send(MESSAGE.encode())
except Exception as e:
    print("Error:", e)
finally:
    s.close()
    print('Connection closed')
In the Visualization VisuStart provided in the Machine Expert project, you can execute the TCP server and wait the connection from the python script.
Regards
This is a heading
