Join our "Ask Me About" community webinar on May 20th at 9 AM CET and 5 PM CET to explore cybersecurity and monitoring for Data Center and edge IT. Learn about market trends, cutting-edge technologies, and best practices from industry experts.
Register and secure your Critical IT infrastructure
Multi-Axis System with Virtual Axis
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • Multi-Axis System with Virtual Axis
  • Subscribe to RSS Feed
Bastian_Schmitz
8
FernandoRodrigues
FernandoRodrigues Support
6
Francesco_Begnoni
Francesco_Begnoni Support
5
LeTomas
5
Back to Machine and Motion Control Forum
Silverfang-
Silverfang-
Cadet
Posted: ‎2024-07-27 09:23 AM
822
Hello Everyone,
I'm new here and relatively new to Machine Expert and Motion Control. I have an application where I need to perform movements of an object using 2 servo drives. So I assume its a virtual axis configuration I need to do but there seems to be very little literature on how to do it.
Can anyone point me to an example of this on Machine Expert or a guide which explains how to do this? I am using a Pacdrive LMC Pro 2 motion controller
  • Programming and Software Development
Francesco_Begnoni
Support
Posted: ‎2024-07-31 02:55 AM
Hi Silverfang,
when you create a new project for PacDrive with Machine Expert, you can choose from different examples. The most common one is the "Template Full", which is already set up for use with 2 Lexium drives and a Power Supply.
If you're new to Machine Expert and don't have prior motion experience, I would recommend attending one of our courses. There are several aspects to consider when implementing a motion system. You can find our training at this address:
https://www.se.com/uk/en/work/services/training/courses.jsp?#TrainingCourses
or you can search for "training" in your regional Schneider Electric website (www.se.com).
Alternatively, there are videos on YouTube posted by some colleagues.
Regards
Francesco_Begnoni
Support
Hi Silverfang,
Regards
Silverfang-
Silverfang-
Cadet
Posted: ‎2024-07-31 09:13 PM
Hello Francesco,
Thanks for your response. Yes although I don't have a wide amount of experience with Machine Expert I have created many applications which successfully run the configuration you are referring to where the axis is a single real axis and a single servo takes care of the movement.
What I need help with is to use a virtual axis (similar to a crank motion where the linear movement creates a rotational path of motion). My actual application demands the system to follow a virtual path of motion by using a twin axis system created by 2 servo motors.
I would love to explore any examples for this (such as robotic arms etc) but I am unable to find resources for this.
This is a heading
