BERGER LAHR WDM3-008.9801 Program EEPROM
Machine and Motion Control Forum
Support forum for Machine and Motion Control solutions, including Lexium MC12 and robotics, PacDrive, Modicon PLCs and I/Os, EcoStruxure Machine Expert Twin, … - from design, implementation to troubleshooting and more, by Schneider Electric
  • Industrial Automation
  • BERGER LAHR WDM3-008.9801 Program EEPROM
Bastian_Schmitz
9
FernandoRodrigues
FernandoRodrigues Support
7
LeTomas
5
Back to Machine and Motion Control Forum
cesarnunosa
cesarnunosa
Cadet
Posted: ‎2025-02-23 03:46 PM
840
I am a Portuguese electrical tecnichian
Someone have a configuration file to program GAL16V8D-25QJ ?
(paperprinted at IC : 493.00  1.001)
Can anyone help me?
Thank you
  • Programming and Software Development
woerk
woerk Support
Support
Posted: ‎2025-02-25 04:59 AM
Hello, please send the drive to the SE repair center.Contact Schneider Electric in your country. Best regards
woerk
woerk Support
Support
Posted: ‎2025-02-24 03:00 AM
Hello, the WDM3-008 is a double amplifier for  3 phase stepper motors controlled via puls/direction signals.It`s not programmable !! The GAL16V8D-25QJ  is a component on the circuit board used for internal processes.The WDM3008.xxx is discontinued for years.   A comparable current device would be a SD326 (https://www.se.com/uk/en/product/SD326DU68S2/motion-control-stepper-motor-drive-sd326-pulse-directio... . Double amplifiers arn`t available anymore.  Best regards
cesarnunosa
cesarnunosa
Cadet
Posted: ‎2025-02-24 10:55 AM
Thank you for your quickly reply .
 One pd the boards ( are twp equação) have the GAL16V8D in bad state and I need chance it for newone.
i want read a “good GAL” for another board ( a good board) but I cant read it because the GAL,s was programmed with security fuse.
Any Idea??
thank you
woerk
woerk Support
Support
