Continue
  • My Subscriptions
  • Events
Unity storing reals on odd addresses. All of my addresses have shifted in a recent rebuild.
Modicon PAC Forum
Showing results forย
Did you mean:ย
  • Industrial Automation
  • Modicon PAC Forum
  • Unity storing reals on odd addresses. All of my addresses have shifted in a recent rebuild.
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Modicon M580
Back to Modicon PAC Forum
Posted: โ€Ž2020-01-15 10:57 AM
10
10182
I have a situation where my program is storing real variables with the starting word is an odd %mw for example %mw1553. My version of the program from a week ago the same real in the same structure was at %mw1554. There is not change to the structure, no new variables added or removed. I was under the impression that all real data types need to start at even address. Can anyone help me find what setting I may have changed or what may have happened here. We are running unity 13.1, and ran an update recently. All I can recall settings wise that has been changed is increasing memory size from 5000 to 7000 and "allowin dynamic arrays". This is an M580 2040
  • m580
  • unity
Replies 10
Omaelk
Omaelk Leader
Leader
Posted: โ€Ž2020-01-22 08:50 AM
9
10156
hey @Anonymous user , thank you for your question
I moved it to this forum when the community of experts will be able to provide you the right support
@Oncom , I know you post a lot about M580 , can you help here please?
Posted: โ€Ž2020-01-23 07:54 PM
In response to Omaelk
The reason was due to unity shuffling memory addresses when it is in simulation mode
Oncom
Oncom
Mentor
Posted: โ€Ž2020-01-23 08:12 PM
7
10129
@Omaelk sure.
@Anonymous user Hi,
do you mean your Odd %MW address is incidentally shifted to Even after you Rebuild?
Actually, Even addressing on Real data type is not new feature. if you try on Unity Pro 8.0 giving Odd address on Real data type variable it would be Error.
www.pamtek.co.id
Posted: โ€Ž2020-01-23 08:29 PM
In response to Oncom
6
10126
yes I know its not a new feature, that is the problem. In our original developed program we put a ddt at address %mw1000 for example. the first word is at %mw1000, the second thing in there is a real and is placed automatically at %mw1002. If you put your plc in simulation mode it will put the word at %mw1000 and the real at %mw1001
For testing a program in simulation mode the plc re positions reals that are in DDTs to be able to start on odd addresses without error. I see this as a huge flaw with the simulator mode, it should act identically to regular operation in terms of memory allocation.
Oncom
Oncom
Mentor
Posted: โ€Ž2020-01-23 11:26 PM
In response to Anonymous user
Ok, now I understand what you are facing.
And I try this also on unity 8.0 and control expert 14.1  and you are absolutely right. ๐Ÿ˜‚
Hi @Omaelk can you mention/forward to M580 Product manager / R&D team. about this issue. Thanks
Simulation:
simulationsimulation
Standard:
StandardStandard
www.pamtek.co.id
Eric_Coudurier
Eric_Coudurier Troubleshooter
Troubleshooter
Posted: โ€Ž2020-01-23 11:29 PM
4
10122
The problem comes from the 32 bits alignment in the M580 platforms. If you map a structure on %MW, due to the 32 bits alignment some holes can be created to align the 32 bits variable on even addresses. (DWORD, REAL...) this is not the case when you use the simulator which is based on 16bits alignment. this is due to the legacy platforms which are all 16 bits, when the simulator was developed. This is explained in the online help in the topic: DDT: Mapping Rules.
KR
Eric_Coudurier
Troubleshooter
Posted: โ€Ž2020-01-24 12:10 AM
In response to Eric_Coudurier
I just forgot something, There is a warning message that can be triggered in case of mapping compatibility. this message is displayed if Control Expert needs to align the 32 bits variable:
Posted: โ€Ž2020-09-30 08:22 PM
8955
Hi @Eric_Coudurier ,
Is there a workaround to this issue other than filling these holes with dummy integers to be able to work on the simulator? Do you know if there is a newer release of the simulator that addresses this issue?
Eric_Coudurier
Troubleshooter
Posted: โ€Ž2020-10-13 06:55 AM
8894
Unfortunately there is no other options. There is no evolution plan in the new ECE version V15 for this issue.
If you use OFS server, with unlocated data there is no issue. the issue is only present when you use located data on %MW.
Eric_Coudurier
Troubleshooter
Posted: โ€Ž2020-10-13 07:06 AM
An other way to overcome the issue, is to arrange the DDT to avoid the "holes". For example, instead of creating a structure like a Word, Real and Real, you can create it using a Real, Real and a Word.
ย
WHATโ€™S NEXT?
Terms & Conditions Privacy Notice Change your Cookie Settings ยฉ 2026 Schneider Electric
