To clear and put M580 CPU to NO CONF state
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • To clear and put M580 CPU to NO CONF state
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Michael_Chan
Michael_Chan Troubleshooter
Troubleshooter
Posted: ‎2019-11-24 07:18 PM
1
5478
Resolution – To clear and put M580 CPU to NO CONF state
For M580, there are two ways to clean the application &configuration:
  • Try to download an application, and before the downloading finish plug-out the USB.
    1. Can use Unity Loader to transfer .STU file, or
    2. Use Unity Pro XL software for transferring.
  • Using Unity function PLC --> Project Backup --> Backup Clear
  • for point 1 you can also use Unity loader
The above result will make M580 CPU into NO CONF state.
Transfer application by using SD-card
Required a good working M580 CPU. Insert the Schneider SD-card into the CPU and download the application into the SD-card. New downloaded application will be saved into the Schneider SD-card.
Use this SD-card and insert into the troubled CPU and power ON it. The application will be recovered and transferred into the RAM of the M580 CPU.
Michael Chan Kum Yuen
  • Connected Products
Omaelk
Omaelk Leader
Leader
Posted: ‎2019-12-02 05:27 AM
Very interesting! Thanks for sharing @Michael_Chan
Omaelk
Omaelk Leader
Leader
