TSX AEY414 Replacement
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • TSX AEY414 Replacement
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Modicon Quantum
Back to Modicon PAC Forum
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-03-11 01:57 AM
5461
Dear All,
TSX AEY414 was installed on a machine which became faulty and I installed new same module.
Problem is that new module don't show any error only RUN indication is ON. but HMI is showing 0 values from that module
I think PLC is not reading the values of new module
can anyone help me what may be the reason?
waiting for reply
Shoaib
  • 00. Read me first
Replies 11
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2021-03-11 02:13 AM
5452
Hello Shoaib,
Please check if the input signals are available. Depending on the signal type connected (+/-10V or mA) you should be able to measure some voltage. If thermocouples are connected this might be more difficult.
If this doesn't help, contact your local support/service team.
Br
Rene
R.Roozee
Sr Solution Architect (SAE Master)
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-03-11 02:17 AM
In response to RoozeeR
5450
Dear Sir,
I have checked the voltage levels and 2-3 volts are present. is it cab be due to SV/PV or RL difference?
waiting for reply
Shoaib
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2021-03-11 02:21 AM
In response to ghulamshoaib
5444
Hello Shoaib,
Contact your local support/service team, they can help.
R.Roozee
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-04-21 12:23 AM
5312
Can I check the module by placing it to some other slot of the same rack?
to place the module on other slot, do I need to make any changes in hardware configuration of the PLC program or not?
please reply
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2021-04-21 12:58 AM
5304
When you place the module in another slot, you have to make changes to the hardware configuration (in software).
R.Roozee
AlastairF
AlastairF Leader
Leader
Posted: ‎2021-04-21 01:24 AM
Re-working module addresses after moving a module depends on the programming environment.
If you are using Control Expert then a drag and drop of the module to another slot will automatically update the associated variable addressing. Cut and Paste does not move the addresses to the new slot.
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-04-21 06:42 AM
5292
if I will change the slot, should I also need to change the addresses?
which software should I use ? unity Pro or PL7?
KenPlimmer
KenPlimmer Leader
Leader
Posted: ‎2021-04-21 07:03 AM
5288
the software which you will need to change the configuration in the TSX57 will depend on the CPU reference. Earlier systems would use PL7 Junior / Pro, updated systems or later installations will require Control Expert for Unity applications.
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-05-24 10:30 PM
In response to KenPlimmer
5103
If I want to test the module TSXAEY414 on some other slot of the same rack, Do I need to make changes in Hardware configuration of the PLC program?
AlastairF
AlastairF Leader
Leader
Posted: ‎2021-05-30 01:38 PM
5060
Yes, you need to add the module type into the spare slot so the CPU can give the module its configuration.
ghulamshoaib
ghulamshoaib
Explorer
Posted: ‎2021-06-14 04:28 AM
In response to AlastairF
Dear All,
Can I use TSXPCX3030 cable for comunicating with CPU P57103?
As I don't have TSXUSB485 cable
Waiting for reply
Shoaib
