NOC 321 IO Scanning
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • NOC 321 IO Scanning
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
Richard
Richard Troubleshooter
Troubleshooter
Posted: ‎2019-11-21 05:24 AM
2
4183
NOC 321 IO Scanning
The BME NOC 321 can forward packets from its Control network (SCADA/Programming) to the Field Network (CPU). However, is it possible to use the IP forwarding to read data from devices on a different domain to the M580?
For example, my M580 CPU is at address 172.168.16. 10 and I want to read data from a device at 192.168.0.120.
When I try to add a device to the NOC 321 I get a message saying that it must be in the same domain as the field network, i.e. 172.16.x.x the same as the CPU.
  • Edge Control
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2019-11-22 02:42 AM
1
4166
Hello Richard,
You can use READ_VAR and WRITE_VAR functions to communicate to other subnets  through a router/IP forwarding.
If you like to use IO-scanner for this purpose, the BMENOC0301/311 modules support IP addresses on a different subnet.
Minimum version of BMENOC firmware should be 2.05 (latest =2.16).
R.Roozee
Sr Solution Architect (SAE Master)
Rebbellyon
Rebbellyon
Explorer
Posted: ‎2024-04-03 02:46 AM
In response to RoozeeR
Hello, can you please explain how to use READ_VAR to communicate to other subnets ?
