NE_INT on array value
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • NE_INT on array value
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Modicon M340
Back to Modicon PAC Forum
Posted: ‎2020-12-19 07:20 AM
4997
I am trying to set an error flag based on the GEST parameter of READ_VAR.
The array PT1_RX1_ST is the input GEST on a READ_VAR block.
The index 1 of the array points the report (0 = no error)
The index 3 of the array points to the length of the response (expecting length = 4)
If I unplug the cable to the remote device, we see the first NE_INT fails (7 != 0, but the output is false)
The second NE_INT block seems to work properly. How can I fix this ?? (I'm new to Schneider PLC)
I'm using M340, the remote device is a M221
Thanks!
I also tried to give the GEST a direct memory address %MW200 and read values %MW201 and %MW203.
%MW201 is always 0, %MW203 seems to update properly
  • 06. EcoStruxure Control Expert
Replies 8
DavidBaker
DavidBaker Explorer
Explorer
Posted: ‎2021-01-14 02:46 PM
4911
Did you ever resolve this?
Posted: ‎2021-01-14 02:49 PM
In response to DavidBaker
4909
@DavidBaker @Nope not resolved, so far no help on the forums....
DavidBaker
DavidBaker Explorer
Explorer
Posted: ‎2021-01-14 02:52 PM
In response to Anonymous user
4905
Odd.  The logic works on my PLC.  What version of Unity?
Posted: ‎2021-01-14 02:59 PM
4901
@DavidBaker Ecostruxure Control Expert V14.1 - 191122A
Would you mind sharing your working program?
DavidBaker
DavidBaker Explorer
Explorer
Posted: ‎2021-01-14 03:20 PM
4893
Mine is for M580.  I'll take a quick look at yours.  Export and attach.
Posted: ‎2021-01-14 03:31 PM
4889
@DavidBaker Thanks any help is appreciated.
See program "Gestion_PTR" : https://we.tl/t-Q4u0jdD42O
FrancisBreysach
FrancisBreysach Contributor
Contributor
Posted: ‎2021-01-15 12:51 AM
Hello
If the problem is always present,
As a workaround,
you could try to invert the logic of the test:
EQ_INT and then invert the input (on the OR_BOOL) with a Not (little circle).
DavidBaker
DavidBaker Explorer
Explorer
Posted: ‎2021-01-15 07:06 AM
You are running your Read_Var continuously (directly from the Power Rail).  The Value of 7 is actually toggling between 7 and 0 so fast that you can't see it.  So it only looks like the logic is not working properly.  I proved this by adding a contact in front of your Read_Var., then disabled the rung after remove the ethernet cable.
You will want to use logic to control execution of the Read_Var.  I use a Pulse Input to execute the Read_Var.
