M340 Modbus command to read input registers
Modicon PAC Forum
Select a Country
  • Industrial Automation
  • Modicon PAC Forum
  • M340 Modbus command to read input registers
Trinxs1
Trinxs1 Leader
19
YONGHO-KIM
YONGHO-KIM Mentor
10
ciupol
ciupol
9
Back to Modicon PAC Forum
MKhalifa
MKhalifa
Explorer
Posted: ‎2022-06-29 04:39 AM
1
3621
Good evening,
I have a PLC P34 1000 and communicate with a flow converter through modbus rtu . but the data i need to read exist on input registers and the manual of converter telling that you have to use command 4 as known but when i'm using read_var the communication halt after a while and the data is not recognized because the data type sent is floating.
by the way i read the holding registers and everything is ok.
thank you in advance
RoozeeR
RoozeeR Mentor
Mentor
Posted: ‎2022-06-30 06:38 AM
The READ_VAR function should be able to read input registers as long as you define the obj type as %IW. The function code to read %IW is 4 .
You mention " the data is not recognized because the data type sent is floating.":
1: does this mean that the input data you read is a 32-bit floating point (real) data? In that case you should adjust the read length to 2 (registers= 32 bits).
2: What is not recognizing the data?
R.Roozee
Sr Solution Architect (SAE Master)
RoozeeR
RoozeeR Mentor
Mentor
R.Roozee
